Not only will you kill the earth with your emissions ... The EPA will come down on your arse with a $20,000 fine if they find out/inspect it.
Rather than go the APR route ($$$), get one custom made with a highflow cat, Seb had one made and installed it for $300 for me. It does make a noticeable difference (The downpipe)
How are they going too see a hollowed out cat.... ?
The fine is 10k (qld) from memory and KNOW ONE has ever been given it. (from memory)
Would a dump pipe from the turbo to cat make much difference in regards to the sound if at all?
Current - MY12 MK6 GTI, CW, Detriots, dark tint, APR Stage 1, blacked out grille, LED tails, Euro plates, suspension "tweaked", VCDS tweaks
"The Ex" Black MY08 POLO GTI - APR,Coilovers,5% tint,stubby antenna, rear sway bar
Neil, Can't answer the back pressure one, and I think I'll need to get the full data set to answer where the power is accurately, but if you revisit the charts (esp. the Mainline ones)....this may send you cross-eyed ..., you can see that while the curves are very similar, the run with the dump pipe gains its power more rapidly that just the tune run.
It's all over by about 5,300 but the dump makes the progression seem much more linear -- the REVO tune delivers significant surge from 2,500 relative to stock, which you really feel; the dump smooths this a bit but nothing is lost down low. In fact, looking at the torque curve, which peaks at almost 300Nm at 3700rpm, it's above 200Nm all the way from around 2000 until 6. And that's what you feel (and what keeps breaking traction).
I'll try to get a photo this weekend
2015 White German SUV
2013 White German hatch
2011 Silver French hot hatch
2008 TR Golf GT TDI DSG
I don't even know what a dump pipe is but it sounds like an impressive mod. With limited car technical knowledge I'd probably find it easier to go for the full APR system, but since that's ~4 times more expensive I'd probably not...
Yeh I definately dont want any change in sound just improved performance.
I have a 3" dump and high flow cat on my car and it does make a different noise.
Turbo spool is slightly louder and has a rougher sound to it (spooling) - Even friends of mine had noticed it.
I found it gives a noticeable increase in midrange (where the turbo is on strongest) and slows the dropoff up top. No real difference to low end power.
