you don't need to take out your tip, just the airbox and intake hose
42dd shifter cable bushings
does it easy to install by myself? just unplug the old one and plug in the new one?2013 4Motion "BLACK BEAR"
http://blackbeartiguan.blogspot.hk//
there is only one screw to undo.
if you are standing at the front of the car, look at the lower right corner of the airbox. there's a screw around that area (a bit deep). remove that and pull the lower half out.
the airbox is held in place by 2 things - the screw mentioned above, and a piece of rubber (don't know what else to call it) somewhere around the lower middle section. this rubber is similar to the one that holds the engine cover in place.
to the guys that have an early build (Oct05 - May06) that has the HWY gearbox, i have a spare set of side/side bushings that i can't use (the later build guys if you're looking at installing these, purchase the Mk5 one that caters for the plastic bracket).
willing to give it away for 10 bucks if you're in Melbourne (can't be bothered shipping, sorry interstate guys) so PM me if you want it!
Group Buy
There is a group buy for going on (been relocated here) for 42DD hardware.
If you want to get these bushes (Mk4 for early builds, Mk5 for later), PM Greg Roles to let him know what you are after.
Hmmmm there is a few different kinds of MK5 onesOriginally posted by noone View PostThere is a group buy for going on (been relocated here) for 42DD hardware.
Would it be the 06-07 ones ??MODS- TOO MANY
Same question hereOriginally posted by vwthunder View PostHmmmm there is a few different kinds of MK5 ones
There are also 5S and 6S varieties in the MK5 06-07 shifter bushings, which one is it?MY2008 VW Polo GTi / GIAC Tune / Forge FMIC / Forge 007 DV / N75 Race / BMC OTA / KW V1 Coilovers / Whiteline Front&Rear Swaybars + Toe-In Shim / Weichers Front&Rear Strut Braces / Full Non-Res Milltek Exhaust / 17" Bora Sport
Yep just emailed them. When i know i'll reply here.MY2008 VW Polo GTi / GIAC Tune / Forge FMIC / Forge 007 DV / N75 Race / BMC OTA / KW V1 Coilovers / Whiteline Front&Rear Swaybars + Toe-In Shim / Weichers Front&Rear Strut Braces / Full Non-Res Milltek Exhaust / 17" Bora Sport
Nothing yet, will let you know as soon as i do mate.MY2008 VW Polo GTi / GIAC Tune / Forge FMIC / Forge 007 DV / N75 Race / BMC OTA / KW V1 Coilovers / Whiteline Front&Rear Swaybars + Toe-In Shim / Weichers Front&Rear Strut Braces / Full Non-Res Milltek Exhaust / 17" Bora Sport
