Polo Problems & Fix Register
This is a sticky topic.
  • Originally posted by Glide_GTI View Post
    my car started doing this too?? did you get it fixed?
    I believe a few have had it fixed with a SW update on their radio's ??? I get it sometimes too.
    aus liebe zum automobil
    • MAKE - POLO GTI
      KMS - 22,000
      MODS - BOV and asthetics
      CAR USAGE - DAILY
      PROBLEM - Air Con
      DESCRIPTION - Air con started to blow hot air.
      FIX - AC compressor faulty. Replaced under warranty
      Cheers,
      John
      • Originally posted by leasaunce View Post
        has anyone here filed a complaint to VW australia?? or am I the only one?
        i have filed a complaint to VWA about the quality of service at a certain Perth dealership.
        VWA need to know what some of their dealerships are doing.
        • MAKE - '06 POLO GTI
          KMS - 42,000
          MODS - APR V2, BOV, BMC filter, SEAT intake
          CAR USAGE - DAILY
          PROBLEM - Engine light intermittently on.
          DESCRIPTION - Faulty o2 (front lambda probe) sensor.
          FIX - Replaced under warranty.
          • I have a grinding/clunking noise that I can also feel through the clutch when I take off from idle. When I lift my foot off the clutch in gear, about half way up I can feel it grinding on something. When I am going slowly (only in 1st gear) over bumps, there is clunking noise coming from under the car, I can also feel this through the clutch.
            Is my gearbox about to fall apart?? My gear changes feel the same as before, but these noises have just started
            • MAKE - POLO GTI
              KMS - 61,000
              MODS - Nil
              CAR USAGE - DAILY
              PROBLEM - Brakes
              DESCRIPTION - Front R/H caliper sticking, chewed out pad & damaged rotor.
              FIX - New caliper, front discs and pads. Replaced under warranty.
              __________________
              Big ups to James Frizelle Southport.
              -Phil
              • Originally posted by [-Polo GTI-] View Post
                Hmmm - see my thread - sort of the same but mine is REALLY bad
                • Make: polo GTI
                  Year: 2008
                  Km's: 5500
                  Problem, after about 1500km noticed an oil leak underneath. Into the dealership it went..after 7 days they decided it was a turbo seal and (apparently) installed a new turbo.
                  Didn't check it for about 6 months (silly me assumed problem was fixed), found oil leak underneath in same spot. Dealership had it for 5 days...another new turbo put on (wtf!!).
                  When questioned they said it was a sealed unit and if the particular seal that is causing the problem goes, it's a whole new turbo required...but according to the service advisor they had never seen it in a polo gti before So, I've now had 2 new turbo's in a car less than 6000kms old...let's hope this is problem solved.
                  • Originally posted by marko View Post
                    Make: polo GTI
                    Year: 2008
                    Km's: 5500
                    holy sh#t, thats like the first time ive evan heard of our polos having this problem.
                    " I wait I resolution derive pleasure this " latest spammer post
                    • Dude, I know. I couldn't believe it when they told me it was the same problem the second time. Seems to me that if it was the turbo (twice), then there was a faulty batch of turbos produced (who makes our turbos anyway?) then VW should be issuing a recall. The problem is I am not good at being an assh0le. I should have demanded to speak to the service manager and got a straight answer!
                        I smell John Hughes Service Centre...am i correct?
                          or it makes you kinda wonder weather it was somthing , somewhere else in the engine causing the problem. yeah thats my problem not a big enough a$$hole , then again i dont hear many callings for a$$hole nurses lol
                          • Originally posted by Bumpknuck View Post
                            on the money there bumpnuck!
                            • thank god hes in perth lmao
                              • Originally posted by mikepologti View Post
                                Hey back off man, Perth rocks! Don't ya know we've got a big..um...ferris wheel thing now which is our claim to fame?
                                So far so good though. Put some white paper down in the carport and no oil since i've had it back.
