Anyone up for a Polo R?
Think Fiat Abarth's and Alfa's Mito GTA - they are some cracking little cars that a true polo R would have to compete with, in conjunction to the JCW Mini and Clio already mentioned. It's coming to be a very busy pocket rocket market - so the Polo could go either way for the greenlight to production.Track Car: 06 Polo GTI Red Devil mkII
Daily: 2010 VW Jetta Highline
Not really that much competition though as the Alfa and the fiat are significantly underpowered compared to what the polo R would be and the mini Jcw is stupidly priced at $50K+ (then add some options and it's more closely priced to an S3). It's only real competitor would be the Clio so there could be a good market for it here.Originally posted by seangti View PostThink Fiat Abarth's and Alfa's Mito GTA - they are some cracking little cars that a true polo R would have to compete with, in conjunction to the JCW Mini and Clio already mentioned. It's coming to be a very busy pocket rocket market - so the Polo could go either way for the greenlight to production.
Probably getting off topic, but you sure about the Mito GTA being underpowered?? I recall reading some power figure in the 140kw+ ball park. The abarth may not put out more power than a stock polo, but power to weight will step it up. but I may be wrong on both calls....Originally posted by callen View PostNot really that much competition though as the Alfa and the fiat are significantly underpowered compared to what the polo R would be and the mini Jcw is stupidly priced at $50K+ (then add some options and it's more closely priced to an S3). It's only real competitor would be the Clio so there could be a good market for it here.Track Car: 06 Polo GTI Red Devil mkII
I've test driven the Mito 1.4 turbo and I've to say I don't like how the powerit's being delivered, laggy than VW 1.8T and the power band always on the top end. And steering is just vague even with sport mode turned on. But if you're talking about Mito GTA, it should be using 1.75ltr turbo rated 240bhp stock - this should be fun!Originally posted by seangti View PostProbably getting off topic, but you sure about the Mito GTA being underpowered?? I recall reading some power figure in the 140kw+ ball park. The abarth may not put out more power than a stock polo, but power to weight will step it up. but I may be wrong on both calls....
I'm all for ~140kw of twincharged AWD drivetrain *if* they can price it accordingly.
If they think they are going to compete up around the $40k mark with the WRX/MPS/Golf GTI they are shooting themselves in the foot.
However, if they can get it nicely between a new Polo GTI and the Golf GTI in terms of both price and performance, I can see a market for it against the ~$35k price cars such as the XR5, Clio Sport, Ralliart Lancer etc.Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Current Ride: Evo 8 MR, Fabia MK3
I'd buy a new Polo R AWD with 140kw over any of those anyday .... including the Golf GTI ...Originally posted by break View PostI'm all for ~140kw of twincharged AWD drivetrain *if* they can price it accordingly.
Traction and low weight is KING !!
AWD doesn't equal low weight.Originally posted by Sharkie View PostI'd buy a new Polo R AWD with 140kw over any of those anyday .... including the Golf GTI ...
An AWD system in the Polo will likely take the weight up (depending on the use of center diff or not) anywhere from 80-150kg. So based on current polo weight, we could be looking anywhere between ~1280kg to ~1350kg (only 50kg lighter than a WRX) based on the assumption that the new Polo isn't any heavier than the existing model.
It may be a case of the AWD system weight and power loss through the drivetrain *may* make the Polo R slower than a Polo GTI if they don't give it a big enough power/torque increase over the Polo GTI.Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Not of you add extra power to it. FWD and lots of power = no tractionOriginally posted by break View PostAWD doesn't equal low weight.
AWD and lots of power = still traction.
IF my Polo GTI (with over 170kw) had AWD, I'd still be driving it ....
Edit: traction offsets weight provided you don't add too much weight ....
As an example ....
A3 2.0TFSI 0-100km/h in 7.2s
A3 2.0TFSI Quattro 0-100km/h in 7.1s even with adding almost 200kg in weight .....
and these 2 have the same 147kw/280NM engineLast edited by Sharkie; 09-02-2010, 11:58 AM.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
FWD traction can be resolved in a number of ways, and the current Polo GTI doesn't have the diff or suspension setup to adequately cope with the power of a tuned 1.8T. That said, it's easily achievable with some work, and you can get some reasonable traction out of FWD cars if setup correctly.Originally posted by Sharkie View PostNot of you add extra power to it. FWD and lots of power = no traction
As an example ....
Hell, look at the Focus RS with it's E-diff setup. It puts 224kw to the ground through the front wheels fine, so why on earth are we struggling with the 150-170kw we can extract from a K03s?
I'd also be skeptical of how the balance and poise of the car will be changed with the weight, because nothing would be worse than a small car that feels 'heavy' for its size.
Put simply, FWD isn't the issue. Suspension/diff are far bigger issues than the drivetrain on a PoloPrevious Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Nope, cant agree, APR's development Polo had a LSD (Pelequin) and trick suspension as well as 215-40-17s semi-slicks and it still had issues putting the power down .....Originally posted by break View PostPut simply, FWD isn't the issue. Suspension/diff are far bigger issues than the drivetrain on a Polo
You'd be spending $10K+ on those and still have issues.
AWD is the easiest way to get greatly improved traction ......
EDIT: And more (UK figures)
Scirrocco R FWD 199kw manual 0-100 in 6s
Golf R AWD 199kw manual 0-100 in 5.7s despite a 200kg weight disadvantage ..... and you can bet they spent some time on the Scirrocco's suspension and diff ......Last edited by Sharkie; 09-02-2010, 12:22 PM.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
0-100km/h is all well and good, but look at 20-120km/h, look at lap times, those give a far clearer idea of overall 'performance' than 0-100km/h.Originally posted by Sharkie View PostScirrocco R FWD 199kw manual 0-100 in 6s
Hell, even look at standing 1/4 mile and standing 1km. Particularly at the terminal speed achieved in those.
You can disagree all you want, but fact is you haven't been in a well sorted FWD and until you do judgment should be reserved on what is 'best' for a small turbo car.
Yes, AWD and RWD will always be superior in traction to FWD, hand down.
What I'm saying is a well sorted FWD at the power levels we are talking is more than capable, and *may* well result in better overall performance, balance, handling, and drivability than AWD.
Edit: For example, I owned a MY05 WRX WRP10. It was dyno'd at 140.3kw @ all fours in stock form, and also ran 5.7s to 100km/h and 13.7s down the 1/4 stock. In contrast, my Polo GTI with GIAC only is around the 120-125kw @ front wheels, but feels stronger in the 20-120km/h zone, even though it's somewhere around 0.5s slower to 100km/h thanks to the traction issues. I would even bet that the terminal speed down the 1/4 would be similar even though my Polo would be slower across the distance. Fix that traction (suspension, diff) and you'll see those figures get much closer.
Then tell me how often you take advantage of a blistering 0-100, as opposed to the rolling acceleration? I very much doubt most people here would find stand still launch acceleration more useful than on the roll acceleration.Last edited by break; 09-02-2010, 12:51 PM.Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Mate, Ive built a MK1 1800 16V Turbo FWD that ran a 12.3s 400m at 198km/h (at 1200m above sea-level where the air is thin) and spent more than 6 months just on the suspension alone .... yet to see any Australian FWD Golf do this .....Originally posted by break View PostYou can disagree all you want, but fact is you haven't been in a well sorted FWD and until you do judgment should be reserved on what is 'best' for a small turbo car.
So I know a little bit about what it takes to make a FWD car go and go well
..... and AWD is just so much easier .... when you've actually built a FWD VW that can do that then come back and tell me all about it ....
As much as I loved my MK1 (and the Polo) I'd take a 200kg hit in weight and AWD anyday .....
So how do you compare the traction needs of a lighter, MUCH more powerful FWD (I haven't looked at your thread yet, but I'm assuming we're talking 230-250fwkw based on the terminal speed). That's double the power of most of the Polo GTI's here with chips and little else.Originally posted by Sharkie View PostMate, Ive built a MK1 1800 16V Turbo FWD that ran a 12.3s 400m at 198km/h (at 1200m above sea-level where the air is thin) and spent more than 6 months just on the suspension alone .... yet to see any Australian FWD Golf do this .....
The traction needs of both are very, VERY different and can't be compared in the real world.Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Sharkie sold his car due to the traction limitations from memory.Originally posted by break View PostYou can disagree all you want, but fact is you haven't been in a well sorted FWD and until you do judgment should be reserved on what is 'best' for a small turbo car.
There was a good tuned cars test where the Rennhaus R32 had the best apex speed out of a number of tuned vehicles.
I had my car holding amazing traction under acceleration, cornering and in the wet. Unfortunately this also meant the drive was uncomfortable for daily driving on Sydney roads.
AWD Polo would be pretty cool, cant see it happening unless its going to be the next big thing for tuner boys (then it should be 2.5T).
