Revo-Technik chip tune & SPS2
  • #16
    ...and *I think* "derived torque" means it is a chassis dyno attempt at calculating the torque at the flywheel...
    2015 White German SUV
    2013 White German hatch
    2011 Silver French hot hatch
    2008 TR Golf GT TDI DSG
    • #17
      Good stuff tim...
      • #18
        awesome chip and great value too, hopefully the new giac program will yield me around the same results
        Red Polo GTI
        GIAC
        H&R Cup Suspension
        Rear Swaybar
        • #19
          so why would it calculate the torque at the flywheel and kw atw??
          • #20
            Because torque at the wheels varies so much depending in what gear you are in 1st gear would have lots and 5th not much, couldn't be bothered working out right now but there are formulas out there....
            • #21
              flywheel to atw conversion
              Does anyone know the formula to convert ATW to flywheel or vice versa?
              • #22
                There's no strict formula, so far as I am aware, as it varies depending on drivetrain configuration. In the case of the Pog, it *seems* to dyno around 93-95Kw ATW, which -- given the factory flywheel rating of 110Kw -- suggests a drivetrain loss of around 15%, which is quite efficient (FWD cars are generally more efficient than either RWD or AWD)
                • #23
                  Originally posted by DUBING View Post
                  just a little question why do pre 2000 model A3 1.8T and GTi's make 148kw @306nm and 2000+ make 158kw@322nm?
                  In 2000 the A3s got an updated engine with Variable valve timing and drive by wire throttle.
                  I think American golfs got a similar treatment in 2000 but aussie MK4 golfs never did so they'll get 148kw regardless of the year.
                  • #24
                    Just a further update:
                    I attended the ACT dyno day, and had the chance to run the car with 'stock', 98 and 100 programs.
                    The absolute numbers were "interesting" but I was more interested in the deltas:
                    - 22.4% increase in power from 98 over 'stock'
                    - a further 4.6% increase from the 100 program over 98
                    Now I can stop wasting time and money on V-Power Racing
                    • #25
                      An additional 4.6% is a fair bit isn't it?
                      Considering its a 22.4% is 98, its 3.8% from 98 to 100, extra 6kw or so... Does APR have a 100 program?
