Control Arm Bushes.
  • Control Arm Bushes.
    Have anyone had any problems with the polo gti control arm bushes, how could u tell?
    what can i do to fix it in aftermarket section.
    jmac gets them in from memory.
    I can get them for like $60 from superpro. But jmac's are way cheaper.
      The rear bushes were soft, fronts are already fairly solid.
      Super pro
      Seat (JMac gets these)
      or Whiteline.
      Not much in it cost wise, have a look for the thread, should still be in the last few pages...
      There is a whiteline video on utube linked in there so you can see what its doing wrong.
      FYI, to get a mechanic to change them is expensive as it takes a while to get all the bits out around them. $50-$100 part, few hours labour (someone please correct me if i'd be led astray)...
      I got the Seat ones which are perfectly good by the looks of them, but went for the Whiteline ones anyway as I got a good price when getting my second swaybar...
        how do u know they are stuffed cuz i have no idea a mechanic told me they were and never got back to me with the quote, anyone tried installing themselves
          Sorry to hijack but does anyone know the part number of the Whiteline bushes?
            PM Jmac mate, he is in brisbane and can supply and install for a great price. The install itself is not easy and even an experienced euro performane shop in Brisbane messed up the install of these exact bushes recently.
            Good luck
              Just ordered another load of solid bushes so if any one needs any chime in
              Jmac
              Alba European
                Jmac
                can i get some please??
                  I might post up another group buy, that way i can extend my order if need be
                  Cheers,
                  Kai consider a set ordered mate
                  Jmac
                  Alba European
                    Jmac did this for me last week and I would like to thank him and recommend this mod. Steering feels/is more precise and I think it also helps with wheelspin in first and second. Seems to be less tramping and a bit more squirrely due to torque steer as more power is getting to the ground.
                      Cheers,
                      Jmac
                      Jmac,
                      May I know how complicated it is to install? The bushes needed to be machine pressed?
                        I'm interested in a possible group buy as well Jmac
                        Edit: I would also be interested in organizing local fitting in Brisbane as part of it too
                        Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
                        Current Ride: Evo 8 MR, Fabia MK3
                          I got 2 tyres fitted today and roatated to the front. The tyre place said my front control arm bushes were gone and would need replacing, they also said they would not touch them and to call VW and ask for part and price to fit, but to sit down when asking - this worried me
                          Now the question is, do i need both bushes for front left and right or just the rear ones for each side at the front (i hope this made sense)
                          Does anyone know of a good installer in Sydney - I live near Parramatta.
                          Any help would be greatly appreciated.
                          MY07 Golf GTi
                          Leather | Sunroof | Bi-Xenon | Reverse Sensors | Bolle Tints | RNS 510 | MDI
                            I would hazard the rear of the control arm bushes. I did a set today and they were the worst ive seen, fully detached.
                            i have ordered a few sets and they will be here soon. Pm me for info
                            As for fitting you will need 12 new bolts, 2 control arm bolts, 4 steer rack bolts and 6 ball joint bolts, all torque to yield and need to be replaced, i change the bolts for less than $30 Well worth it as ive had one Gti lately with a loose control arm bolt. My opinion they are a must so please factor them in, if you are taking them some where to be done pm me for part numbers.
                            To answer the bush install, yes you really need a press. You can do it in place , first couple i did in place very difficult. Press them in for the win.
                            A wheel alignment is also req afterwards.
                            Pm me for torque settings for the torque to yield bolts too, being torque to yield the torque settings must be right too.
                            If you are pondering a sway bar upgrade now would be the time to do the bushes with the subframe out, at the same time do the dogbone, and to be honest if you are pondering susp upgrade leave it all to then. If the subframe is dropped it really helps when doing the sups as the right hand driveshaft hits the subframe and can be a pain when installing.
                            Jmac
                            Alba European
