This says that i have to get a .4 or more reaction time to not foul, how did eddy get .009 and not foul. Is each drag strip different. Also i noticed that eddys runs were done at 18deg i wish mine was.
Hoyhoy.
Hey, Shaneth, put it down to pure ARSE or judgement or mathematical calculations, I done it. Not going to try again & stuff a good record.
P.S. To gain .4 sec., go one light earlier, call it cheating if you like, but it works.
yeah but the willowbank site says if you get under .4 then you will be fouled. but you werent. See what i think it is is WSID takes .4 off your reaction time and puts that on the slip. So my best was .54 so i in fact took off .14 after the green light came on. DOes that make sense or am i barking up the wrong tree.
For Sale 2006 VW Polo GTI Have a Look
CUSTOM CODE
Phase 2
Hoyhoy.
Reaction time: The time it takes a driver to react to the green start light on the Christmas tree, measured in thousandths of a second.
A perfect reaction time on a full tree is .000 at WSID.
What else can I say.
P.S. I was outside the perfect time by .009sec. so it could have been better.
Eddy im sorry if my post sounded like i was saying you should have got fouled. I was just pointing out how different Drag strips are different with there reaction time measurements. i.e perfect reaction time is 0.4 for willowbank and 0.00 for WSID
CUSTOM CODE
Phase 2
Firstly good onya for going out there with a stock polo on a hot night and having a go .
The times are pretty good , it looks like the launch is where your loosing time , if it wheelspins too much lower your tyre pressure slightly . Getting the launch right is critical in getting a good et it doesnt affect your mph as much though . Ive found that launching it around 3500 rpm is probably the best rpm for a stock turbo and gently slipping it so it doesnt grab too hard . That way its right on boost when it does grab , also I would be leaving it in 3rd across the finish line , you loose about .3 sec on a gear change ! But overall thats a good result on a hot night . With a perfect launch and the temperature around 20 you should dip into the low 15's . Also a bit of weight reduction helps too !!! . Looking forward to seeing some more timeslips soon
Hoyhoy.
Shaneth.
This statement is spot on. My best run was the only time I hung onto 3rd peg. Also dropped the tyre pressures down to 25 lbs & the revs on take off, after the first run which was all wheel spin.
P.S. At Eastern Creek the reaction times are excluded from actual times on the amateur nights.
Speaking of tyres pressures, what would you recomend for normal driving.
Hoyhoy.
Kia here is what Shaneth & Myself come up with earlier on.
Quote:
Originally Posted by shaneth
Well went to the servo to check my tyre pressure and found that they dont use BAR incriments on there gauge so i have done a bit of research to save everyone else.
Tyre Bar Pressure PSI pressure
Front 2.8 40
Rear 3.2 46
Now according to Michelin uk site it says to add 5 psi to the cold recommendation if your tyres are hot.
I hope this helps
Hoyhoy.
Shaneth, These figures are O.K. if you have 5 passengers & luggage.
I myself have'nt had anyone in the rear seat as yet, so then the figures change a bit.
Fr. 2.6--38lb. [ As recommended for 2 passengers.]
Re. 2.4--35lb. [ " " " " " .]
As this little girl is mine & the wife has her own car, I changed the pressures even to these figures.
Fr. 2.5--36lb. [ This also helps with the torque steer.]
Re. 34lb. [ " " " " " " " .]
__________________
ha, i ran at calder park last fri as well, stock as a rock and 34 psi in the front tyres lol reaction time lol, 15.4 at 88 mph... i'm ok with that... 4 now. The other lane is my cousin in his 94 wrx, didn't even launch and still pull 14 flat bastard lol. Traction control is off, full weight with 3/4 tank.
The next day i put it on the dyno at a dyno comp at a local shop, bit wierd as its lower than i expected, may be the dyno setup that day. the same wrx got 152kw@14psi at all 4.
Mine...
Mine...
21KW drivetrain loss is excellent. What did you think it should be?
Mine...
My other half (blue XR5) said he chatted to you He called me up after and said I should come down and run mine but I was busy
I would have thought 93 would be about right but we all know what dyno's are like you could have taken it down the road 10 minutes after and gotten the 93kw reading. Unfortuneately dynos cant be relied upon 100% for power figures. In fact my Last car which was a 1993 corolla had 86kw@w and weighed in around 1050kg and the best i could do was 15.9 and it had lsd as well. What im getting at is that its all relitive.
CUSTOM CODE
Phase 2
I just got the temp APR chip and the best I can manage for 0-100 is 6.3-6.4 sec....
also I went to the drags last night..... toooo much wheelspin... even when shortshifting.... ran a 15.1 at 94mph.... but wheel spinning all way thru second gear...lol
any suggestions on launch to reduce wheelspin?
