Originally posted by Wand Weaver
FAQ and DIY Polo
Acceptable Delivery Kilometres ?
How many KM's do you run your car in for ?
What's a good rpm to shift to save fuel?
I hear there were specific rev ranges where people shift to achieve better fuel efficiency... What's the recommended rpm in our polos? or rpm where you have found to save fuel?
Polo GTI - Do you have to use 98 RON?
Hi, Just a general question about the fuel. It recommends using 98 RON. Now I probably will use it as its only about $4-$5 difference a tank and for the amount of money i budgeted each week for fuel, I will have enough. However I have noticed you cant always get 98 RON everywhere so theres going to be times on the
Fuel Consumption ?
Hey...so … Just wanting to know what type of fuel consumption you people are getting? Also at how many ks does the fuel light come on? For both standard or Modded GTI’s Mine just does not seen right... My light is turning on at about 350-380ks.Then I’m lucky if I get another 20ks out of it, before I go fill up.
Engine Oil ?
- Ben
2008 Jetta 2.0L FSI
EBC Greens in QLD?
Thanks Timbo. Anyone know where to get these in Brisvegas?Originally posted by Timbo View PostIf you want slightly harder (and less dusty) front brake pads, you can get EBC Greens. The part number is DP21479, and they are actually the upgraded pad listed in the EBC catalogue for a Skoda Fabia (and a couple of other VAG platforms). They cost around c.$150
Any good brakes parts supplier that handles EBC ought to be able to source them. The struggle was to find the right part number, and now you have it
2015 White German SUV
2013 White German hatch
2011 Silver French hot hatch
2008 TR Golf GT TDI DSG
Another option is Ferodo 2500's.Timbo and I have used both EBC's and currently the Ferodos,and prefer the latter.They are working well from cold,are quiet and less dusty,and should be a good track day pad.Cost is up [about $280 a set]but they seem a lot better than the EBC's.Part number is FCP1419H.I got mine from V Sport in Sydney phone 99679 8644.Talk to Tony Dunn-he's very helpfull.
Len
Yep, the Ferodos are good. I'll reserve my judgement until I have tracked them, but they are certainly cleaner than both the stock pads and the EBCs.
With the Ferodos, you have to bridge the pad wear connector, otherwise the dash light stays on2015 White German SUV
I've compiled the info of the FAQ - with some additional information into a website. I'll be expanding this over the next few weeks to cover the remaining engines and models (I'll probably roll both the 1.4 Match/Club into one page).
Feel free to point out anything that's missing (yes, I'm aware that the TDI link doesn't work yet - that one's my current WIP), and if people would like me to host dyno graphs etc (still searching for that elusive official graph) - I'll be happy to do so as long as they're not too big. I do plan to cover chips at some stage, but not just yet.
The site at the moment is at a pretty early stage - so expect it to change in both appearance and content reasonably regularly at this stage.
Edit a few days later: Polo TDI info page up
Last edited by Wand Weaver; 26-08-2007, 09:27 PM. Reason: Site has been taken down for maintenance. Link has been removed to prevent a 404.
Lights
Got myself a full set of Phillips Diamond visions over the weekend but am having trouble installing them all.
Headlights were a breeze, parker on drivers side easy too.. I can get my hand in on the passenger side to pull out the other parker because the battery and all the **** on it is too close. Any tips without having to pull the battery out?
Also, have tried the fog lights yet as I don't want to breaak anything.
FYI - High beems are H1s, Headlights are H7s, Fog Lights H4s and parkers obviously wedge globes.sigpic
Thought I might post the reviews I found prior to getting the car. This FAQ thread is probably the best place for it.
English:
Britain's most detailed and trusted car reviews: Choose the perfect next car by reading Parkers' expert and independent reviews.
Australia's most reputable and independent motoring experts bring you the latest car reviews, comparisons, news and auto content.
Norwegian
Aftenposten gir deg ny innsikt og et raskt nyhetsoverblikk. Vi hjelper deg med å forstå hvorfor ting skjer, og hvordan verden henger sammen.
Ya! the driver side is very easy but for the other side you don't need to pull out the battery but you must have a small hand to do the job. i replaced mine already its a pretty hard job to do it cuz i got a big hand... LOL i'm thinking to replace the fog lights too i through it was H3...but you found out is H4s... lucky that i didn't buy the H3...Originally posted by dodgeGTI View PostGot myself a full set of Phillips Diamond visions over the weekend but am having trouble installing them all.
FYI - High beems are H1s, Headlights are H7s, Fog Lights H4s and parkers obviously wedge globes.2013 4Motion "BLACK BEAR"
http://blackbeartiguan.blogspot.hk//
Just had to change a headlight bulb on the wifes Polo and found this quick how to that makes it very easy.
- remove the rubber cover
- pull off electrical connector
- slacken the 2 T20 torx screws at 3 o'clock and 9 o'clock (no need to remove them). You will need a stubby or angled driver.
- twist black plastic retaining plate 15 degrees anticlockwise
- pull out bulb, noting its orientation (tab at 12 o'clock)
- reverse to replace the bulb
Cheers Al
Forge Turbo Inlet Pipe Clamp Sizes
Screw Type Clamp
3 x 11 – 16mm
1 x 17 – 25mm
1 x 25 – 35mm
1 x 40 – 55mm
1 x 60 – 80mm
