MAF sensor part #
  • MAF sensor part #
    Hi All,
    I am hoping someone could give me the part number for the MAF sensor to convert the housing from Airbox outlet connection to pipe connection to connect to a pod filter (is it the same at the Golf MKIV GTI?) for a Polo GTI?
    Kai I know you've done this mod. Do you have the part # on hand?
    Thanks everyone in advance.
    Cheers,
    John
    If you get a rubber neck filter. The clamp can shrink down onto the maf sensor.
    Saves abit of money.
      I gave up on having a pod there tho. Heat got to it too much. Heated up the pod which then heats up the air as it travels through the pod.
        Thanks for the advise Kai. I'm looking at making a custom CAI soon. Just wanting to know how others have got around the MAF sensor housing issue.
        Cheers,
        John
