Originally posted by Plautos
View Post
Meet my Polo!
Almost...
I'm happy with the gain of power after 4500rpm, it is helping, but it is not enough, I'm going to test as soon as possible a more aggressive APR software.
I'm using the 95oct software, I'm going to try the 98oct and the 100oct. I will see what can happen. They have a tool called V-tune, it is capable to make adjustments over the software.
This Saturday I tried the APR 98oct and 104oct software.
I had to choose the 98oct because with the 104oct the lambda meter was showing the AFR trying to be stoichiometric and not rich how it should be at full throttle.
So, now I have 290HP at the engine and 270HP at the wheels and 41kgm of torque.
95oct
98oct
104oct
This is altogether superb my friend. Just read through the whole thing here and it has been enjoyable.
JmacAlba European
The pin is riveted.Originally posted by GTIJNR View Posthehe, exactly what i wanted to do
did u weld the pin after? how did you secure the pin?
My first thought was to weld the pins, I remove them breaking the rivet head and I notice that they could be riveted again. In the pictures you can see my employee hammering the rivet.
But weld still is a possibility. Probably it will work fine.
