Fuel Pump
  • Fuel Pump
    Has anyone upgraded there fuel pumps?
    Ive come across a spare 044.
    Will i need a aftermarket FPR?
    I have a drop in tank VF unit , but you wont need it unless your going gt28 or larger , you should still be ok with gt28 (unless your doing 2l conversion and highflowing gt28 )
      its more that i have one to use.
      So i was going to use it.
      It wont do anything at all??
        No point , your getting enough fuel so there is no need to try and push more in !
          okay thanks.
          I know with othercars ive had and worked on fuel pump normally allows you to have a longer rev range.
          But that also requires retune.
            Keep it for when you do the turbo upgrade. That + FPR + larger injectors will see you make 220+kw atw ....... (and obviously a custom tune)
