New suspension on the polo
  • New suspension on the polo
    Fitted the hottuning suspension up on friday night, Just in time for DOVW, SO far feels really tight and is so flat through the corners now. And yes I have pics, There is more pics up on the DOVW (WA) thread to, Im the only polo there.
    BMW E36 M3 3.0L LTW - SZYBKI
    VW Up! 1.0L - WGN WERKS
    Looking great matt although the front looks a tad higher which is good I suppose as it is much easier to adjust.
    Now for the laptimes
      Thanks Robin for all the help to Yeah just need the height for speed bumps and such, feels like a go kart in the corners
        So how is it comfort wise. Do find it bumpier or smoother? Or maybe bumpier at low speed but smoother at high speed?
          looks good mate. Have to update your sig pic
            looks awesome mate.
              Bumpy at crawling speeds but once you get going I cant really feel much, But I have mostly ever driven cars with coilovers so kinda hard for me to comment on the comfort.
                Definitely looks the goods
                '04 BMP MkIV R32 #144
                search getnew
                  So how different is it from the under-steering, under-sprung, under-dampened, body-rolling POS the stock TDI Polo is with the suspension work?
                  PS - I love the GTI looking red bit you've put on your front grille.
                  2008 Volkswagen Polo 1.9 TDI
                    Bilsteins
                    I have a '06 Polo TDI with Bilstein B14 coilovers in it. Totally transformed the car. The coilovers are a little harsh and bumpy at low speeds, but out on the open road the car is awesome. Bumps are soaked up, corners flat etc etc.
                    I was motivated to change the suspension after taking the Polo for its first ride on the open road (as opposed to Aussie freeways). Felt as though it just about failed to take a corner at 100 kph. Certainly not confidence inspiring.
                    I think that the ride height on the TDI can never be as low as a GTI due to the taller diesel engine. Mine was lowered ~5cm from stock to give 105 mm clearance (was being a little conservative). No clearance issue so far...
                    My car still has the eco-tyres on it, and they will be replaced next...wife says I have to wait until the OEM tyres are worn.
                    B.
                      Does the diesel engine sit lower than the petrol engine? Less ground clearance to play with?
                      Paul
                        Much better Like a whole new car, less swatting in acceleration, heaps less under steer, and the only understeer you get is very controllable, but the biggest diff is the amount of body roll, there is like none at all hey, it stays completely flat
                          I don't know for sure, but it seems to me that if you lowered a TDI to the same extent (wheels nearly at the top of the guards), the sump guard would be scraping on the ground. As it is, with 105 mm of clearance from the chassis, the sump guard itself only has about 80 mm clearance.
                          My TDI looks similar to polo_spec_ds in terms of wheel to guard clearance.
                          B.
                            UPDATE ON SUSPENSION
                            Well I have had the coilovers on for a month now and learnt acouple of things along the way.
                            The car with the RSB on the hardest setting is most dangerous on "targa like" roads and would be better to have it on the softer setting I found. IMO
                            The car still feels firm but not so firm you lose your mind. It is very comfy in the city with the stops and starts, constant road surface changing and you dont bottom out either on speed humps and etc.
                            Havent had a chance yet to track it, That will come in due time and im looking forward to wiping the smile of some of the more "powerful" cars.
                              Finally got the pogo on the track today, And OMG.............Awesome!! So flat through the corners and grip was just amazing!!!
