So, I've recently returned to the world of Polos and have picked up a GTI that needs a bit of TLC. I've cleared most of the fault codes, but the following remain.
Physical symptoms are that the power steering doesn't want to work and the ESP light is on in the cluster as well as the ESP OFF button being illuminated.
If anyone's willing to have a go at deciphering the below or has experienced and fixed these problems before, I'm all ears and would be incredibly grateful!
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.LBL
Controller: 6Q0 907 379 AS
Component: ESP 8.0 front H06 0003
Coding: 0002550
Shop #: WSC 31414
VCID: 8E6FBAE5D94F
4 Faults Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
01315 - Transmission Control Module
004 - No Signal/Communication
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 -
01314 - Engine Control Module
000 - -------------------------------------------------------------------------------
Address 08: Auto HVAC Labels: 6Q0-820-045.LBL
Controller: 6Q0 820 045
Component: Klimaanlage X0840
VCID: EAA7D6758567
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes-----------------------------------------------------------------------------
Coding: 0002550
Shop #: WSC 31414
VCID: 8E6FBAE5D94F
4 Faults Found:
P1647 - 000 -
VCID: EAA7D6758567
1 Fault Found:
