Hi
Recently purchased a 2008 Polo 9N for my daughter. Seems to be a good little runner but unfortunately both rear doors do not operate via the central locking system even though the central locking is installed in all 5 doors. The front doors and the rear hatch work fine via the remote, the internal buttons on the drivers side door and the drivers side key lock.
Checking with VCDS-Lite and Comfort Command module (46) and then using measuring blocks - Group 9 reports the status of Rear Door Left & Rear Door Right as "Uninstalled" which is not correct as I spent all day yesterday pulling the drivers side rear door unit out (and putting it back in again) - please refer to attached screenshot.
So, I'm figuring it's either a wiring problem for both doors (suggesting a fault common to both doors - maybe a separate plug into the CCM for the rear doors) or I'm wondering if somehow the car is configured as a 3 door car instead of a 5 door car.
Would be grateful if someone could help out with a wiring diagram or any insights into vehicle configuration relating to 3 or 5 door set-up/coding.
