I'll have a completed 98 ron tune very soon. Before going down the path of a dedicated E20 tune, I'm pretty sure I can test E20 out using some rudimentary tuning myself. The old Lemmiwinks software lets me globally adjust my main fuel term and have control over low load fuel trims and allows global timing adjustment too.
Assuming I'll have duty cycle head room in the injectors I'm more than prepared to have a fiddle with E20 with two eyes on the logs of course. How it'll respond to timing changes is usually pretty clear but I'm not sure RE fuelling. Is E20 so different that the ideal lambda will need to deviate much from the 98 ron position? If say my best safe 98 ron fuelling is at 0.81 lambda or the like, will I likely need to move a couple of points richer or leaner from there once E20 is in the tank or will it most likely just be a case of nudging up the timing and seeing where that heads? If the results are tangible then for sure I'll get the other ECU tuned specifically for it.
edit: actually the VAG logs put fuelling into lambda, not afr and lambda is lambda not matter what your fuel is so if I go to E20 then I should just adjust for fuelling for whatever lambda the 98 was roughly on I think.
