Hi there, I cant find enough information about this anywhere. Do u guys know if the original timing belt tensioner pulley on BJX/BBU engines has the washer between the engine block and the tensioner pulley? if it does are u meant to put it on the new pulley if it doesn't come with the new kit?
The thing is that The tentioner pulley I'm looking to buy is specificely for BJX/BBU engines but doesn't come with the washer (like other pullyes for the other 1.8t engines with diffferent engine codes) this one has this circular raised section on the back of the pulley where normally washer sits and I'm not sure if that raised section is there to act like a washer or u're meant to use your old one and put it on.
1st: the picture of the tensioner for BJX/BBU (with raised section on the back ) and the 2nd one for different 1.8t engine codes with the washer. Thanks for any help.
