Originally posted by sambb
View Post
In comparison petrol doesn't act anywhere near as well as a combustion temp coolant, so we really have to pump a lot more petrol in to make much difference. That's commonly not enough in the above example, so we have no choice but to retard the ignition to prevent the knock, which in turn increases the temperature, so we throw even more petrol at it. That circle of pain really kills the horsepower and eventually the engine, too much petrol washes the oil of the bores and we have ever increasing blow by and eventually ring sealing failure.
Swapping the same engine from pump 98 to E85 lowers the engine coolant temp by 10 degrees and the oil temp by 5 degrees. As a result there's more capacity in the cooling systems before they over heat to start off with.
Gary
