G-8VXWWTRHPN SAI Pump, after market Replacements - VWWatercooled Australia
  • SAI Pump, after market Replacements
    Hi All
    Just had the SAI pump fail on my mrs Polo GTI, just wondering if an after market $70 ebay "generic" replacement will do the trick?
    Example
    Have looked at getting an OEM replacement but they are fairly pricey $400+
    It's currently stock, I know I could do the delete and tune it, but really looking for a cheap solution.
    2016 Golf R, APR Stage 1
    2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
    I removed mine a couple of months ago...
    $30 ebay cable, 5 minutes to code it out, an hour or so to remove all the junk - gone for good
      Thanks simon, you may be right, deleting it sounds like the cheapest route. I currently have the cable and VCDS ready to go
      Can you just delete the pump and cap off the combi & box, or do you have to remove all 3 components inc Combi & N249?
      With the resistors, did 30ohm 10w from Jaycar do the trick?
        yep, I just removed the pump and capped the combi and airbox (though I capped the combi at the head - no difference). I left the N249 in place and put a screw in the air line with a bit of sealant
        I didn't use any resistors, because it's coded out in the map - the ECU doesn't go looking for it, doesn't try to turn it on - completely ignored
        go here and download nefmoto flasher/logger: NefMoto ME7 ECU Flasher and Data Logger Version 1.9.3.2
        read the instructions for reading your ECU and see if you can get a .bin file out of it. I'll help you from there
          how'd you go? with nefmoto, in a nutshell you choose your cable from the drop-down, then click 'connect slow init', then on the 'KWP2000 Flashing' tab choose the "ME7 29F800BB.MemoryLayout.xml" file and click 'Full Read Flash' - takes about 3.5 minutes for my cable
            Don't reckon it will read out of its got Apr in.
              must be a different car to his sig...
                Sorry for the late reply, hectic weekend!
                Will try and have a go at it this weekend, seems straight fairly forward.. its on my mrs car which is stock tuned.
                  I have a file to switch out the sai on a stock gti
                    Thanks for the heads up on this program, Had no idea you could do this kind of stuff without a proper Ross tech cable.
                    I'm fairly tech savvy but haven't haven't had much luck getting my old blue KKL ebay cable to work as it appears to have a CH304T USB Chipset not compatible with the FTDI driver.. Nefmoto wont detect it. I'll shop around for a new cable
                      by the time I got it to work I'd bought 3 cables, first I didn't realise the CH304 chip wouldn't work, so I read more and found that the cable needs to have the FT232 chip, so I bought one of those, but when it arrived it had a CH304 chip, so then I bought this cable from this seller
                      VAG COM KKL OBD2 USB Cable FTDI FT232RL Chip + 2x2 Cable for VCDS Lite US SHIP 603281795254 | eBay
                      but mine was $30 and came from Sydney (location said it was in Sydney, arrived in a few days)
