Sport Select Retrofit on 6C Polo - Help Needed
  • Sport Select Retrofit on 6C Polo - Help Needed
    Hello !
    I am looking for an owner of a Polo 6C with factory fitted DCC ( Sports Select ). Desperately need help !
    Have retrofitted a 2015 6C Polo with the DCC and almost everything works perfect. Only one problem remains. We cannot command the Sports Select to switch to Sports mode.
    Here is the write up on the project done. CBX RNS510 & Accessories: Polo Sports Select : Dynamic Chassis Control on 6C Polo
    Would really appreciate a helping hand with the VCDS information that we need. Here is the VCDS scan of the car after the work done.
    Thanks a million.
    CBX
    PHP Code:
    Monday,08,May,2017,17:50:50:24118
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 17.1.3.0
    Data version: 20170320 DS267.7
    www.Ross-Tech.com
    Dealer/Shop Name: cbx auto
    Workshop Code: 305 91777 091777
    VIN: WVWZZZ6RZFU049836   License Plate: POLO LEOW 1,2 DCC AFTER ERROR
    Mileage: 25628km-15924mi   Repair Order:
    Chassis Type: 6R (6C0)
    Scan: 01 02 03 08 09 14 15 17 19 44 5F
    VIN: WVWZZZ6RZFU049836   Mileage: 25628km-15924miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    5F-Information Electr. -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CJZC)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 027 BB    HW: 04E 907 309 AF
       Component: 1.2l R4 TSI   H21 8228
       Revision: R5H21---
       Coding: 01250012230411080000
       Shop #: WSC 31414 790 50316
       ASAM Dataset: EV_ECM12TFS01104E906027BB 001006
       ROD: EV_ECM12TFS01104E906027BB.rod
       VCID: 65CB5EAE643FF0697A-8030
       CAN Converter 01:
    No fault code found.
    Readiness: 1110 0001
    Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
       Part No SW: 0CW 300 046 G    HW: 0AM 927 769 K
       Component: GSG DQ200-MQB H43 5206
       Revision: 00043014    Serial number: CU501409196312
       Coding: 0014
       ASAM Dataset: EV_TCMDQ200021 001001
       ROD: EV_TCMDQ200021.rod
       VCID: 3E79D1C2A12983B1DB-806A
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
       Part No SW: 6C0 907 379     HW: 6R0 907 379 BA
       Component: ESP9.0i       H03 0002
       Serial number: 08506045140922
       Coding: 23DD2885892733C9111C106C0057C41491CC88080005C7090000
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
       ROD: EV_Brake1ESP90iBOSCHPQ26.rod
       VCID: 6CDD2B8A87D5C12125-8038
    1 Fault Found:
    1219 - Coding invalid
              U10DA 00 [009] - -
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 155
                        Mileage: 25628 km
                        Date: 2017.05.07
                        Time: 17:39:07
    Address 08: Auto HVAC (J255)       Labels: 6C0-907-044.clb
       Part No SW: 6C0 907 044 A    HW: 6C0 907 044 A
       Component: Climatronic   H02 0104
       Serial number:  1409101A-0029
       Coding: 200020011001100001
       ASAM Dataset: EV_ACClimaValeoPQ26 003001
       ROD: EV_ACClimaValeoPQ26_VW26.rod
       VCID: 224105B23591C751DF-8076
    Address 09: Cent. Elect. (J519)       Labels: 6C0-937-089-V1.clb
       Part No SW: 6C0 937 089 A    HW: 6C0 937 089
       Component: BCM PQ26 Hi4R H06 0047
       Serial number: 001028001732
       Coding: 03001840425300DB4B844000402703881000580253010000000000000000
       Shop #: WSC 91777 305 91777
       ASAM Dataset: EV_BCMA0 004003
       ROD: EV_BCMA0_004_VW26.rod
       VCID: 2E59E182714973314B-807A
       Drivers Door Control Module:
       Subsystem 1 - Part No SW: 6R0 959 802 CH    HW: 6R0 959 801 CF  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  003 9610
       Serial number: KU0KU025091442688034
       Coding: 1400A1
       Front Passengers Door Control Module:
       Subsystem 2 - Part No SW: 6R0 959 801 CF    HW: 6R0 959 802 CH  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  003 9610
       Serial number: KU0KU015091442581170
       Coding: 0400A1
       Relative Air Humidity Interior Sender:
       Drivers Door Rear Control Module:
       Subsystem 4 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
       Component: J389__TSG_HR  003 8610
       Serial number: KU0KU016091442593683
       Coding: 1400A0
       Passengers Rear Door Control Module:
       Subsystem 5 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
       Component: J388__TSG_HL  003 8610
       Serial number: KU0KU020101442934135
       Coding: 0400A0
    Address 14: Susp. Elect. (J250)       Labels: 6C0-907-359.clb
       Part No SW: 6C0 907 359     HW: 6C0 907 359
       Component: DAEMPFUNGS-SG H04 0007
       Serial number: 13061602000033
       Coding: 80
       ASAM Dataset: EV_SwitcDampeContiTemic 001004
       ROD: EV_SwitcDampeContiTemic.rod
       VCID: 6AD12D928D21DF1157-803E
    Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
       Part No SW: 6C0 959 655 B    HW: 6C0 959 655 B
       Component: VW20Airbag01D 001 0330
       Revision: --------    Serial number: 003LN000ZYH4
       Coding: 88CCC000000000005C0000CA008800000000
       ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
       ROD: EV_AirbaVW20BPAVW26X.rod
       VCID: 3261F5F2657157D12F-8066
       Side Sensor Driver Front:
       Subsystem 1 - Part No SW: -----------    HW: 410 821 408 14
       Component: SideSensor_Df  151 0800
       Serial number: 3575H009F1627C1271FT
       Coding: 2D2D2D
       Side Sensor Passenger Front:
       Subsystem 2 - Part No SW: -----------    HW: 410 821 408 14
       Component: SideSensor_Pf  151 0800
       Serial number: 3585H00BF1628C01A09R
       Coding: 2D2D2D
       Side Sensor Driver Rear:
       Subsystem 3 - Part No SW: -----------    HW: 442 152 709 14
       Component: SideSensor_Dr  1CA 0148
       Serial number: 3517A00A31730323909X
       Coding: 2D2D2D
       Side Sensor Passenger Rear:
       Subsystem 4 - Part No SW: -----------    HW: 442 152 709 14
       Component: SideSensor_Pr  1CA 0148
       Serial number: 3527A00A5176F6017144
       Coding: 2D2D2D
    Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
       Part No SW: 6C0 920 730 A    HW: 6C0 920 730 A
       Component: KOMBI         110 0260
       Coding: 2724090820000008000808000000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009036
       ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
       VCID: 1F470C4606E3EAB9F0-804A
    Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
       Part No SW: 6C0 909 901     HW: 6C0 937 089
       Component: GW MQB A0     H06 0047
       Revision: --------    Serial number: 001028001732
       Coding: 030100046F0A560071000000000000010001000000000000000000000000
       ASAM Dataset: EV_GatewA0Lear 001001
       ROD: EV_GatewA0Lear_VW26.rod
       Multi Function Steering Wheel Control Module:
       Subsystem 1 - Part No SW: 6C0 959 442     HW: 6C0 959 442   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAT  H04 0019
       Serial number: 2561420373502242AB1B
       Coding: 240000
       Battery Monitoring Control Module:
       Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
       Component: J367-BDM  H08 0223
       Serial number: 51281E41142821930261
    1 Fault Found:
    131699 - Control unit for information electronics 1
              U1054 00 [009] - No Communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 155
                        Mileage: 25628 km
                        Date: 2017.05.07
                        Time: 00:12:49
                        Supply voltage: Terminal 30: 13.1 V
                        Terminal 15: On
    Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
       Part No SW: 6C2 909 144 M    HW: 6C2 909 144 D
       Component: EPS_TRW_ALow  322 3211
       Serial number: CE9O0276
       Coding: 0007
       ASAM Dataset: EV_SteerAssisUDSTRW 011021
       ROD: EV_SteerAssisUDSTRW_011.rod
       VCID: 336FF0F69A6B5ED924-8066
    Address 5F: Information Electr.
    Cannot be reached
    End---------------------(Elapsed Time: 02:43, Deb=2)-----------------------
    Jimmy
    CBX
    http://jimmy-cbx.blogspot.com/2011/0...ts-by-cbx.html
    ^^^^ hm..... interesting project and kudos for getting this far!! I don't know the answer, but it appears from the DTCs that the solution might be in the ABS coding section (perhaps?).
    Clearly the Gateway module error and the error in the MIB module is related - what changes were made in the retrofit to generate this DTC? But solving this problem might be the first step (to obviate the possibility of a connection to the Sports selection issue)
    Here's why I think this is an important first step in your process: I'm aware that the Polo 6C isn't built on a MQB platform, but it does have MQB-ish like characteristics ( in the structure of its CAN bus network and in some of its control modules - like the BCM and MIB). On MQB vehicles, the Sport's function can be enabled by setting to active the two adaptation channels in the MIB below:
    [5F-Information Electr. -> Adaptation]: IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function
    [5F-Information Electr. -> Adaptation]: IDE04300-ENG117760-Vehicle function list BAP-Brake_0x26
    And by setting the lower nibble of Byte 29 on the ABS module to hex 03 (0011). Now your ABS module only has 26 x Bytes, so the ABS part of the process doesn't apply - but I suspect the MIB part is necessary (I think).
    The problem is that the Byte/Bit structure for the ABS module is not known, but my suggestion (for what its worth) is that you search the Ross Tech forum for autoscans of the Polo 6C with factory fitted module @ address hex14. Of course, the more autoscans that you can find the better, but if you can locate sufficient of these autoscans, see it you can find a pattern in the ABS code-strings that isn't in your module.
    If it helps, you can use my handy-dandy code-string to Byte/Bit converter, which you can download HERE
    Good luck
    Don
      Hi Don,
      thanks for the pointers.
      Will try the various codings that I can find on the subject ABS. I hope that we can resolve the invalid coding issue though I don't understand what the ABS have to do with the Sports Select function.
      Fingers crossed !
      Jim
      Jimmy
      CBX
