6R GTI DSG fluid screw up help
  • 6R GTI DSG fluid screw up help
    Hey, so ive got a 2013 Polo GTI with the 7 speed DSG and i need to refill the transmission fluid (not the megatronics fluid).
    Yes i know the fluid is a life time fill item and yes i know i should never have to touch it but i have to refill so thats what im doing
    Im going to go to VW to see if i can get 2 litres of oil and if i cant FUCHS and Liqui-Moly do a 75w-90 GL4 fluid to suit.
    I just want to make sure im looking at the right diagram to refill it. Below is the refill procedure im using. Is this right? Or should i just refill it through the breather hole? Im going to put exactly 1.7litres in.
    Thanks Blake
    Yes, via the breather with the special tool.
    I think I paid about $50 for mine from VW.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      Great! Can it be done without the special tool?im just thinking if i cant get one from VW this morning. Also does VW have this fluid usually in stock? Or do you use an aftermarket brand?
        It'll be overnight from Sydney.
        You may get lucky and be able to jam a piece of hose over the fitting.
        The oil is nothing special, just 75W90 full-synthetic gear oil.
        '01 Beetle 2.0
          Ive done it. I got the oil from VW and spoke to the service manager and he said to just pull the cover off and put it in. So thats what i did..... Same as what was in the image above. Seems to be all good. Haven't done a proper drive yet just up and down my basement but all seems to be fine.
          Thanks for your replies though made me feel better about it all. There doesn't seem to be many people that can give you any help on this. I just kept being told 'you cant do it yourself' well turns out you can and its not really any harder than an engine oil change
            Also one other question I had was is there anyway I can ensure the amount of oil is correct and it's all good to go? If it's not will the car shift like crap or make noises or anything?
            I've taken it for a drive and it runs and changes smoothly but I feel if it's not done right it'll take a little before things start screwing up.....
              The oil you're changing is not the DSG oil, but the gear oil for the diff.
              You probably won't get the full 1.7L in, but you'll get pretty close.
              '01 Beetle 2.0
                I got the full 1.7 in and could've gone heaps more... the selector area once the cover is off is a big area that you could fill with heaps of fluid but i only put 1.7 as stated everywhere that ive read. I did pull 1.9l of oil out so i think Ve may have overfilled it when i have the clutch pack replaced 18 months ago
                  Supposed to have 1.9L of oil in it, they updated the capacity following a campaign that was carried out.
                  Volks Handy
                    Mmmm right... is there somewhere i can find that info?
                      Did you find the answer to that or did he just drop a bomb and walk away?
