G-8VXWWTRHPN 2015 Polo GTI DSG Jitter - VWWatercooled Australia
  • 2015 Polo GTI DSG Jitter
    Hey Guys,
    just notice a jitters in my 2015 GTI polo when i slowly accurate around the 1500 RPM mark mostly Gears 4 and 5.
    called Volkswagen they didn't seem to concerned and aren't seeing me till next Thursday .
    im not going to drive it till volks sees it.
    just wanted to know if anyone has experienced this before?
    Thanks.
    Describe jitters.
    Just keep driving it .. if it breaks, they will give you a new gearbox since it's brand new.
    RS
    R
      pulls stops pulls stops pulls always that type of pattern.
      but in sports or driving in high RPM range no issue at all just in stop start traffic i notice it badly.
      jeez that's harder than what i thought to describe that.
        If it feels like the clutch isn't grabbing it probably means its slipping. If that's the case then it sounds like you might be requiring new a new clutch pack.
        There have been a bunch of people with the previous gen Polo (probably newer 6C's aswell just unheard of as of yet cause theyre so new) that have had their clutch's replaced due to the wonderful shift points VW program into the gearbox.
          Probably clutch slip which is common with that gearbox.
            25k km and 15months old and its slipping!
            thanks again guys! will post back once VW looks at it.
              My clutch packs were replaced at 40k kms.
              Ben
              2015 Polo GTI & 2019 Golf R
                Do they do it under warranty or do they say it's normal wear and tear?
                Sent from my LG-H815 using Tapatalk
                  Under warranty.
                  Ben
                    update - took it into VW Five dock looked at it and couldn't reproduce the problem YAY my luck! took one of the lead techs out happened twice.
                    they have taken it for the next two days to see what going on - Lead Tech said it seems to be miss firing but petrol and everything else has come back with no fault.
                    will update once they have something!
                      Hi there , just wondering if the techs ever worked out what the issue was? I think i maybe having the same issues at low rpm [emoji19]
