2013 Polo GTI MY13.5 - Front Rotor Size
  • 2013 Polo GTI MY13.5 - Front Rotor Size
    Hey guys,
    can anyone confirm that the MY13.5 GTI runs 312mm size front rotors? From memory someone mentioned that they increased from 288 to 312mm from 2013 onwards?
    yes MY13.5 have the larger front rotors.
    See photos below:
    Dust shields and caliper carriers are different.
    MY13.5 rotor (note internal ventilation)
    MY13 rotor (same weight if not more than MY 13.5)
    OCTAVIA 3 PARTS FOR SALE:
    Brushed stainless rear bumper & cargo protector, Octavia III Combi models
      Excellent. Thanks for the info!
        Do both rotor sizes use the same pad type?
        See photos below:
        [ATTACH=CONFIG]22180[/ATTACH]
        [ATTACH=CONFIG]22179[/ATTACH]
        [ATTACH=CONFIG]22181[/ATTACH]
        [ATTACH=CONFIG]22182[/ATTACH]
          Yep, pads are identical. I should add that the carrier for the caliper is also different to allow for the caliper to sit further out from the hub.
          It can be easily swapped with no tools once caliper is unbolted from the hub.
            Great
            Thanks for the info
