Changing polo tsi Springs to gti springs
  • Changing polo tsi Springs to gti springs
    Hey guys
    just wondering if anyone has done this and if it can be archived by a novice.. I've watched a few YouTube vids and it looks do able but I don't have Spring compressors. Or should I let a wheel joint put them in?
    And would I gain a slightly lower ride and the car feeling a bit stiffer? I want to lessen body roll
    i don't want it low just sit nice with some 17" eventually
    thanks
    If you want to change the front springs and keep the current shocks, you need spring compressors
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
      I have complete GTI suspension for sale if you are interested. No need for spring compressors. Just bolt in
      Sent from my SM-G925I using Tapatalk
        how much? Plus if your in NSW gonna need it to get sent over to melboune
          Basically I'm looking at changing all 4 springs so yeah I'm gonna need a spring compressor.. Anyone have one spare
            Send me a PM and we can work something out.
              Pm sent
                They are pretty cheap (for cheaper ones):
                Toledo Coil Spring Compressor Macpherson - 311285 - Supercheap Auto Australia
                ...even less on eBay...
                sure you're probably only going to use them once though
                There is probably someone around that could lend you a set... probably?
                  Dont change to the gti springs, they are too hard for a road car.... I love the gti but at 110 on the freeway it can get rough! Pretty sure thats why VW have put adjustable sus as standard now.
                    I agree the GTI suspension is firm.
                    But thats why you buy a GTI for a sports version.
                    If you want a family car you buy a commodore.
                      The dampers in polo are absolute rubbish. The barely control the spring oscilations.
                      You are better off changing the dampers to Koni or Bilstein.
                      As a DIY you need the spreader for the hub joint and the correct tool to undo the top nut of the strut.
                      You need to be a bit imaginative if you don't want to undo the drive shaft bolts.
                      The rears are a doddle and take about 15m per side. The fronts take about an hour per side.
                      You can do the dampers & leave the existing springs in and it will transform the car. If you do just the springs on the existing dampers it will be even more over-sprung / under-damped.
                        I don't drive that far most days for work and I don't mind it a little firmer
                          I don't think you understand what under-damped is. It's not about firmness - it's about the body bouncing like a pogo stick
                            Hmm never thought of that. Thanks for the idea. I'll check prices but I have found a full set of gti springs and shocks for a very good price in which I will end up getting. Unless the price for the shocks are at the same price
