Hey everyone.
I know the horrid Touch Adapter has been brought up many a time, but I hadn't found the exact information I was looking for.
I have a late 2012 Polo 77TSI Comfortline that I had a 3rd party bluetooth module for music plugged in via the MDI, it was working surprisingly well until it looks like it died last week, errors of unsupported device. So I went and started my searching again as to what other options we have. After reading a few threads I kind of got the impression that if I get the adapter itself VCDS coded out I can direct all calls and music through the RCD310. Is that correct or does that only work if I have the RCD510??
I have found someone in Bris that can assist with the VCDS part of things. If someone knows the codes required.
I'm not sure I would want to spend the, up to $800 to put the RCD510/bluetooth in just to have music.
I also came across this unit on eBay (VW AUX Bluetooth Adapter autoradio auto 12pin Quadlock f RCD 210 RCD 300 RCD 310 | eBay) but wasn't sure if that would plug into where the MDI or 3.5mm AUX port was at the moment. I'd also came across the same unit but plugs in via MDI.
Any help is appreciated.
