CAYB 1.6 TDI loss of power and engine noise
This topic is closed.
I'd bet your injectors are stuffed. Ours were replaced at 70,000 km under warranty (thank god) because the car wouldn't idle, ran rough, stalled and sounded similar to yours. The car is now at 115,000 km with no further issues since the injector replacement.
Here's the video I made before the injector replacement: VW Volkswagen Polo 6R TDI 2011 Strange Engine Noise Broken Injectors - YouTubeAlex Aescht
MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
thanks for that..Originally posted by alexaescht View PostI'd bet your injectors are stuffed. Ours were replaced at 70,000 km under warranty (thank god) because the car wouldn't idle, ran rough, stalled and sounded similar to yours. The car is now at 115,000 km with no further issues since the injector replacement.
i'm thinking mine is going to be a combination of bad injectors, injector timing and injector pump.
Injector timing is totally electronic so I'd doubt that's the issue here. Pump should only go bad if petrol was run through instead of diesel.Originally posted by Hilal View Postthanks for that..
Injectors can fail for many reasons, such as poor quality fuel (water in fuel, or other contaminants). Injectors these days also just don't last very long as they're run under incredibly high pressures.Alex Aescht
sounds very similar to this..
Just a question: what fuel station would you usually fill up at? We've had heaps of issues with Woolworths/Caltex and so have friends and family.Alex Aescht
Water in the fuel can destroy the piezo injectors very easily, doesn't take much for a failure.Originally posted by Hilal View PostIt might be dirty fuel but really, i wouldn't expect it to be this bad if it was the dirty fuel..Alex Aescht
