Radio code question
  • Radio code question
    I removed the RCD310 from the Polo and installed a RCD510. Now the 510 has to come out for reasons I won't go into, so when I put the 310 back in, will it work or will it need the security code? Thanks.
    If the RCD310 was installed at factory then fit the unit. Turn on ignition and then turn on the radio and it will activate the code automatically. If its not from that car when it was built then you will need the code.
    DARKHORSE DEVELOPMENTS
    BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. ​0420839266
    BRISBANE/GOLDCOAST/IPSWICH
    www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
      Thanks!
        The car can store up to 3 codes in memory
          Handy to know, thanks.
