Our driveway is a normal one - not particularly steep or tall at all, small step up from the gutter (measures 50mm). No other car has ever scraped its nose on the driveway, but Polo does. Also scrapes reversing out at snails pace. Also scrapes on shopping centre driveway. No problems with various speed bumps.
Ground clearance to the under-nose black plastic air dam is 155mm. Clearance to painted chin is 215mm.
So the 185/60 R15 tyres are probably about 578-580mm diameter, whereas the 215/40 R17 are probably 608-610mm (Continental doesn't provide specs but got from another manufacturer). If the suspension is the same, then there could be 15mm more ground clearance in the Sport pack or GTI. If the suspension is lowered for those, then they might be the same.
Interested to know the nose clearance (esp to black under-nose air dam) of Polos with 17inch wheels.
