Upgrading My RCD310
  • Upgrading My RCD310
    Hello!
    I have just bought my mums 2010 Polo TSI comfortline but it only has a RCD310 stereo/head unit and i wanted to upgrade it to either RCD510 or a RNS510!
    I really only want it for the USB plug and play plus a better looking entertainment unit
    I would love bluetooth but i'm not that good with installation and it seems like quiet a bit of work!
    I'm leaning towards the RCD510 just because i don't really need the GPS system but wanting to know which way to go with an aftermarket solution!
    Im just a bit confused with all the different types and things! All help is appreciated!
    Hi mate. Can pick you up a RCD510 for around $250-300. It will be plug and play so easy install. BT kit would be good if you got the 9w7 as it displays on the RCD screen. Also if you payed for the higher price RCD510 it will have a camera socket so later down the line you could install a reverse camera flip badge
    BRISBANE / GOLD COAST
      Do you know if the unit will respond through the controls on the steering wheel also?
      Thanks for the reply!
        Yes it will mate
          I have a RCD510 and USB cable to fit your car it will plug I and work as normal has code the lot I will post it to you the lot for $240
            The unit is 8 weeks old
              I sent you a Private message simon!
