Originally posted by LukePolo
View Post
1. Drive the car from cold for around 20 minutes so it is thoroughly warmed up. This is critical, because until you have driven for this long and engine is 100% fully warmed up, you don't hear anything - it is perfectly fine, just like it was for the first 18 months. The first 10 minutes when I drive the car it is great. No funny noises.
2. Ensure all windows are wound up, stereo and air flow fans / aircon is off.
3. Find a quiet back road with inclines so that you will have to work the engine a little bit and also so there is no traffic to mask the sound.
4. Lightly accelerate the car up the incline in either 3rd or 4th gear at around 1,200 RPM to whatever is the legal speed limit, using around 30% throttle.
When you do this, on my car you will hear a very distinct metallic sucking sound when the throttle is opened. It will stop when you close the throttle. Sort of like an industrial sized coffee percolator but with very metallic flavour as if there is a dry bearing or maybe like a steel roller being rolled over (lightly) sand-covered concrete.
The car will then continue making this noise for the rest of the drive and even after you have gotten home and the car is at idle with no load at all. Infact you can check it here as well. After the drive, open the bonnet and put your ear facing downwards towards the gearbox overlooking the inlet manifold end of the pipe from the turbo to the inlet manifold. You will still hear that steel roller over sandy concrete sound even at idle.
It is absolutely unmistakable unless you are all but deaf (or your car does not have the problem). The technician quite clearly heard it as well and said it was normal, but did not explain to my satisfaction as to why it started suddenly and the car never made it for the first 18 months prior.
The above steps are just so you can learn what to listen for. It is sufficiently loud that the only way you don't hear it is if there is thick moving traffic surrounding the car or you have the stereo at unhealthy levels.
What I do agree with the technician now that I have analysed it more is that although the water pump does sound the same, it is definitely coming from where he said - whatever that thingy is between the end of the turbo pipe and the inlet manifold (the technical term for the area concerned is the funny round black plastic thingy at the end of the long black tube coming out of the turbo
My concern is not only that something is about to break, but whatever breaks might causes something even more expensive to fix. And also that no one would buy the car if they heard it because like me they will just think something is about to break on it. I just can't believe this sound really is normal, despite what VW tells me. If it was, no one would buy the cars. I certainly wouldn't have if I had heard it on the car I test drove.
