In order to remove the front struts (lower spring fitment) the wheel speed sensor needs to be seperated from the wheel hub. This is so that the suspension arm can be lowered further in order to gain enough clearance to remove the strut.
Has anyone uncoupled this sensor connection? What do you press/turn/pull to seperate the sensor itself from the connecting wire? Or have people removed the whole sensor (by unbolting it from the wheel hub) and not seperated it from the connecting wire? The sensor appears to have just one bolt holding it in the wheel hub and I assume you just undo it and pull the sensor up and out?
Kind regards
VEEEUU
Kind regards
VEEEUU
