Installing aftermarket springs.
Guy I disagree because I have put my mk4 golf on our laser aligned at work and yes, there was a change in camber caster and toe, but until vw start building in the proper adjustments then there is no way whatsoever to change the camber and caster.
Jake, it's not going to change enough for you to worry about adjusting. If you're worries about the change in toe, then mark 2 lines on your driveway, jack the car up, do the springs and then check it again after dropping it back on its wheels.
