VCDS Coding; New features?
  • #76
    Originally posted by gavs View Post
    No possible my friend, have tried many different times, many different ways. The module for it is not available.
    Will using a used MY10 speedo on my MY12 make it work? I know I will have to go to the dealer(online) to have it recoded on the immobiliser again
    • #77
      So long as its a speedo with a "H" at the end of the part number.
      Examples:
      6R1 xxx xxx H
      1K0 xxx xxx H
      • #78
        I believe it works on the newer polo's too (MY 13+)
        You have to do indicator celebration instead
        • #79
          Any clue how to turn off the highline instrument cluster (the one with full MFD and temp n feul gauge) from displaying the error - check coolant level. My 6R, 1.2TSI doesnt come with the coolant level sensor in the coolant overflow tank. The OEM cluster didnt show this error, but after I swapped to the highline cluster the low coolant light keeps flashing + check coolant level msg on the MFD.
          I know in SRI-UDS Adaptations you can choose if the cluster is connected to the oil temp/oil level sensor. Any idea if we can do similar adaptations for the coolant level sensor?
          • #80
            For those with ESP9.0i Try this to turn your ASR off to a LONG PRESS ESP FULL OFF button.
            USING VCDS:
            1. "Select Control Module"
            2. Select "03 - ABS Brakes"
            3. Select "Coding - 07"
            4. Copy & Paste your long coding into a text editor
            5. Change the byte 6 number from "0" to "8"
            6. Change the byte 14 number from "0" to "1"
            • #81
              I have discovered these few channels in the ABS module.
              Channel 21 SMALL/LARGE
              Channel 35 ON/OFF
              Channel 51 ENABLED/DISABLED
              Channel 58 Center/EARLY/LATE
              Channel 73 On/OFF
              Any VAG VCDS experts know what these controls? I am trying to delay ASR activating which allows some slipping and if possible activating it only after 30km/h
