As most of you would be aware i made the bracket to place the golf camera in the polo. Since then i have installed a thew RVC for friends (and friends of friends) with out a drama. but had not got around to doing my own before i had to leave for work for 2 months.
So now that im back i finally got around to installing my own. it all went quick and smooth did the coding and then went to give it a spin. I got nothing. the camera poped out and the screen went to the black one with the writing at the bottom. so i satrted to process of diagnosing. Plugs. tick. wiring. tick (even check the continuity from front to back) so i did a VCDS scan and it was all red NAV, CAN, radio. media player, telephone, Cent electrics.
i am baffled. i unplug the camera, reset and rescaned but still the same. everthing is still working like before (besides the camera).
Any help would be appreciated. alternatively if there is anyone in hobart that has a camera they havnt installed yet and could lend it for ten minutes to check in exchange for help with there installe
here is the log i did.
Sunday,16,December,2012,17:33:02:09411
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Chassis Type: 6N0
Scan: 01 02 03 08 09 15 17 19 25 2E 37 44 56 77
VIN: WVWZZZ6RZCY239359
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 1010
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 068120397
Coding: 3CB02BAF08A3000001380800252B0ED100C0410F6006000020 0000000000
Shop #: WSC 12469 483 00190
VCID: 4581E91ACC852530523
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 150212 05 54 0403
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD
Component: J387__TSG_BT 008 1611
Coding: 18BC30
Subsystem 4 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H08 0010
Coding: 830000
Subsystem 5 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 18BC32
Subsystem 6 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 18BC32
2 Faults Found:
00901 - Back-Up Lamps
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 209
Time Indication: 0
00907 - Intervention load Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 11
Reset counter: 170
Mileage: 4110 km
Time Indication: 0
Date: 2008.14.07
Time: 14:32:58
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 002300
VCID: F0EFE8CE23875098515
3 Faults Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Time Indication: 0
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 210
Time Indication: 0
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 210
Time Indication: 0
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7662106636
Coding: 010000
Shop #: WSC 00788 648 00255
VCID: 295945AA40DDE15056B
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 210
Mileage: 4110 km
Time Indication: 0
Date: 2008.14.07
Time: 12:16:53
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 H HW: 1T0 035 680 H
Component: RNS-MID H64 4020
Revision: AB001001 Serial number: ______________
Coding: 00010440040000910000
Shop #: WSC 12345 123 12345
ASAM Dataset: ------------------------- ------
VCID: 3365A7C29211AB80EC7
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 210
Mileage: 4104 km
Time Indication: 0
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 210
Mileage: 4104 km
Time Indication: 0
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 F HW: 5K0 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661899331
Coding: 0A00000000000210
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA_VW25.rod
VCID: 285F40AE53D7D858495
3 Faults Found:
9457427 - Negative output audio channel for speech/telephone
B104F 13 [008] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 210
Mileage: 4110 km
Date: 2008.14.07
Time: 16:46:51
9457171 - Positive output audio channel for speech/telephone
B104E 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 210
Mileage: 4110 km
Date: 2008.14.07
Time: 16:46:51
0022 - Radio
U1066 00 [008] - No Communication
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 210
Mileage: 4110 km
Date: 2008.14.07
Time: 12:16:51
End ---------------------------------------------------------------------
Chassis Type: 6N0
Coding: 03302D
Coding: 18BC30
Coding: 18BC30
Coding: 830000
Coding: 18BC32
Coding: 18BC32
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 209
Time Indication: 0
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 170
Mileage: 4110 km
Time Indication: 0
Date: 2008.14.07
Time: 14:32:58
Revision: BF046001
Coding: 002300
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Time Indication: 0
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 210
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 210
Time Indication: 0
Coding: 010000
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 210
Mileage: 4110 km
Time Indication: 0
Date: 2008.14.07
Time: 12:16:53
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 210
Mileage: 4104 km
Time Indication: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 210
Mileage: 4104 km
Time Indication: 0
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 210
Mileage: 4110 km
Date: 2008.14.07
Time: 16:46:51
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 210
Mileage: 4110 km
Date: 2008.14.07
Time: 16:46:51
0022 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 210
Mileage: 4110 km
Date: 2008.14.07
Time: 12:16:51
