Hi, for a while now our polo has had this extremely annoying/dangerous thing where every time just before the DPF light comes on (about a day before) it will start to run rough and will quite often stall when you depress the clutch coming up to a set of lights, or a roundabout. The car went into VW for half a week a while ago to replace an EGR valve and replace some vacuum hoses that were chewed by rodents and at the same time we told VW about the issue, they said that after these two things were replaced that it would not happen again. Well, yesterday the car started to show its telltale signs of beginning to regenerate the DPF (idling high, idle fuel consumption down, exhaust running really hot, engine becoming louder etc.) and what do you know, going downhill at about 60 km/h in 4th towards a red light and then depressing the clutch, the rev gauge goes from ~2,500 rpm to normal idle (800 rpm) then below that to about 600 rpm, then up to 1,400 rpm, then to 0 rpm.
We do generally short trips, so I can understand why the DPF is regenerating so often, but surely it shouldn't make the engine stall.
A big problem though is that VW said they can't fix it unless they can actually be there when it happens, which is difficult because most of the time it does it on the way to work in the morning which is in completely the opposite direction.
So does anyone know if this is a known fault and has anyone experienced it? If it happens again ill try to capture it on video to prove it happens.
