Can you post a pic of the location as I can't find any on my 6R. Sorry I am very new to this and have not modded any vehicle.
How to change/replace the fog light bulb on your Polo 6R
 Wow thanks. Do we need to cut any material to expose the screw?
 I plan to import smoked EU/AU style tail lamps as the ones in India are bland (Cost cutting measures, afterall, Highline model in India costs just AUD $10944.54)
 Since we are at it, do we have a tutorial to convert LHD tail lights to RHD? I don't intend to cut/splice wires as it will void warranty.Last edited by sanke1; 15-12-2012, 02:10 AM.
 Well you have to rip out the lens for the foglight (pliers work quite nice!) and then get a red bulb to replace the foglight on the other side. So rip the red lens out of the left tail light ad put the clear reversing bulb in and put a red fog light bulb in the right tail light (or you can leave it if you don't intend to use the foglight).
 On the plugs there is one wire on the bottom that either controls the fog or reverse light.
 Take the left tail light for example the plug has a pin empty at the bottom. De-pin the pin just above the empty spot ad put it in the empty spot.
 With the right light it's the same but in reverse. The plug has a free pin 2nd from the bottom. De pin the bottom pin and move it up to the empty spot. That's if. If you don't do this you won't have reverse or fog lights. Everything else if fine though and will work out of the box.
 I'm also think of going down the LED fog light path as well. Anyone know of any good tried and tested brands? Did a search on ebay but there so many sellers to choose from and I don't always trust their photos.Originally posted by Bagachin View PostInteresting, i might give those bulb a try next time. Again, I know what a foglight should be properly used for, but i don't need it for most of my driving time, so "looking good" is my number 1 priority here.
 Thanks for the example, do you mind let me know where you got them from? that web address shown on the pic?
 I have changed the Fog Light (Driving Lights) globes to Multi LED style... I have some images here somewhere. The first sort I bought off E-Bay, were a bit big to fit in the housing (in diameter).
 The second set worked brilliantly. They do not offer as much light but they match the LED DRL's in the Polo really well.
 Also changed the cornering globes to a similar type.
 Easy to change and just have the white look that I wanted.Last edited by steveyoshi; 26-04-2014, 03:27 PM.Owner and Operator of 2013 Polo GTI - Sunroof - Xenons - Reflex Silver
 APR Stage 2 Tune - HP Carbon Airbox - Jetex Stainless Cat Back Exhaust - APR I/C
 Plus a few other bits and pieces.
 Would mine share some pics?Originally posted by steveyoshi View PostI have changed the Fog Light (Driving Lights) globes to Multi LED style... I have some images here somewhere. The first sort I bought off E-Bay, were a bit big to fit in the housing (in diameter).
 Sent from my GT-I9505 using Tapatalk2013 POLO GTI Black
 2005 MKV 2.0 FSI Black
 They are not bright enough to be fog lights in my opinion...
 they were useless in my opinion and I wanted them to match the other lights.
 Originally posted by BenT View PostThe fog lights are not driving lights.
 Sent from my SM-N9005 using TapatalkOwner and Operator of 2013 Polo GTI - Sunroof - Xenons - Reflex Silver
 if I put 7.5w LEDs in the fog lights won't the car throw a light out code?Originally posted by steveyoshi View PostI have changed the Fog Light (Driving Lights) globes to Multi LED style... I have some images here somewhere. The first sort I bought off E-Bay, were a bit big to fit in the housing (in diameter).
 Does it say in the owner's manual? Euro cars generally state all globe types.Originally posted by cyclonic View PostWhat size are the cornering globes in the fog light? Same as the fog itself?Alex Aescht
 MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
 MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
 but not looking for xenon-look type H8s -- does anyone know what the standard H8's are?
