I'm keen to replace the OEM standard filament bulb that is used for my daytime running lights (DRLs), with an LED bulb.  Just to be clear, as there are various flavours of DRL on the Polo, this picture shows the bulb I'm referring to:
I've tried using this LED bulb, but it does not light. I've tried the bulb both ways round in the socket, but no joy. I don't get any errors on the dash and reinserting the original bulb works fine. I've tested the LED bulbs with a 12v circuit and they work fine.
I don't want to go the expense and hassle of a full LED retro-fit, I was just hoping to do a simple bulb swap for the desired effect. Can anyone think why this would not work and what a solution might be? If LEDs aren't an option, are there any bright white conventional bulbs that could be substituted for the feeble yellow affair that is fited as standard?
