Originally posted by Mr Codger
View Post
DSG Fault on GTI
the sequence of events is: It is in D, I stop behind other cars facing uphill. I am using the footbrake. We are all waiting to stop again at the STOP sign ahead. When I depress the accelerator there is no power because it remains in idle. After a few seconds it goes out of idle and I can move off. It is rather alarming and have to be careful that the car does not roll back.
It is the same or similar to the problem with the Polo GTI of Snedden 9485 on this site.
I have not had it happen using the paddles and only once, I think, in Sport mode. It is just that if I use the particular intersection described above, it will happen sooner or later. I am always in D when it happens, except once it Sport. I will keep trying it and will have to speak to the Dealer.
Originally posted by Mr Codger View PostYes. Mine is a 2011 Polo GTI and the same issue. Usually it happens when I have tried to resume after stopping on a hill. As you ....
Difference is I was not really in M but in S using the pedals. It was a hill start but before I stopped, I was down shifting, and maybe the S did the same and ended downshifting to "0".
As it has not happened again, I won't worry for now.2011 Polo GTI 5DR - Candy with Comfort Pack, RNS510 and 9W7"Beggers are not Choosers"
Originally posted by Mr Codger View Postthe sequence of events is: It is in D, I stop behind other cars facing uphill. I am using the footbrake. We are all waiting to stop again at the STOP sign ahead. When I depress the accelerator there is no power because it remains in idle. After a few seconds it goes out of idle and I can move off. It is rather alarming and have to be careful that the car does not roll back.
A good question. When I thought about it, I have been using left foot braking.
Have just been around the block (where the problem occurs on the hill ) about 10 times, using right foot braking and in those 10 runs it has been going normally. Will give it another try during the week.
When I told my wife about using left foot braking, she said "what difference would that make". Perhaps you can help.
Originally posted by Mr Codger View PostA good question. When I thought about it, I have been using left foot braking.
Ummmm, so correct me if i'm wrong, but to replicate the sequence of events I would do this:
Come to a stop on a hill.
Hold car stopped with foot on brake pedal.
Attempt to take off again by taking foot off brake and putting onto accelerator.
Car hessitates, seems to be stuck in idle and doesn't go anywhere briefly.
Car then takes of as normal.
If this is what is happening, there is absolutely no fault in your gearbox or software, this is the hill-hold feature that stops you rolling into the car behind you as the gearbox engages the clutch.
Remember that this is 2 manual gearboxs fundamentally and it is controlled by a computer. The computer has to do exactly what you would (when in "D" especially) by taking the car from neutral, putting it in gear and taking off. If you don't touch the accelerator pedal, you will roll back as the car will automatically release the brakes after a small while, there's nothing fancy for the hill hold, the car just applies the brakes to hold you in place instead of rolling back.sigpic
mine doesn't do it frequently but this is what I notice:
- car is almost but not stationary
- has done it in both D / manual mode (I usually fllick it down to D at those speed so it doesn't kick down to 1st)
- car would've kicked down to 1st gear
- no throttle response and clutch is usually engaged (feels like idle)
a quick flick to N and back to D would usually get it going againLast edited by Lams; 15-08-2011, 08:28 AM.
Originally posted by gavs View PostIf you don't touch the accelerator pedal, you will roll back as the car will automatically release the brakes after a small while, there's nothing fancy for the hill hold, the car just applies the brakes to hold you in place instead of rolling back.
It's bloody frightening because the first time it happened I didn't even look to see if there was anyone behind me.sigpic
it depends what you mean by brielfly. The problem is/was that I am stuck there with the car not going out of idle and it is worse when you are on a hill. Have taken your comments on board and will report again if there is any further issue. At present I am inclined to the view that the problem has arisen because of left foot braking. (see post from VW Fanatic).
you can left foot brake, but you've got to be really conscious not to "rest" your foot on the brake (which a lot of people who lfb do). Any slight constant pressure is enough to confuse the brake override safety features...
Originally posted by ATYPIC View PostThe underground car park at work has a 30 degree ascend to get out but I have to stop half way up the ramp in order to hit the 'open gate' button. After putting my foot on the brake, I wait for the gate to open (slowly) and then release the brake to accelerate but the dsg has absolutely disengaged itself and I roll completely back to the bottom of the car park.
The car has a "hill holder". So you don't have to maintain pressure on the brake with your left foot while you apply throttle with your right foot.
