Polo GTI High Oil Usage - Discussion Thread
This is a sticky topic.
  • Originally posted by Polo Princess View Post
    Given some of the Castrol Edge products are considerably cheaper from places like SuperCheap Auto than from my dealer and given that it seems I am going to be through oil for a bit longer what should I be buying??
    Go to Supercheap / Repco / Autobarn. Ask for an oil that is VW 504.00 approved (Shell & Penrite are likely contenders). Make them show you on the bottle or the techspec on the internet where it says 504.00 approved. That is all you need. If it's approved then it's been to the VW labs, the mfr has paid the fee & VW issue a letter of approval.
    Repco recently had the Shell 504.00 on special for $50 which is a bit of a bargain. Shell Helix 504.00 is factory fill in many VW group engines.
    I think a lot of people over-analyse these things.
    • Ok so went to livo VW for an oil consumption test and he told me there have replaced the hose on 2 cars so far and he said both of them went worse after the part. He said one of teh cars went through 1.1 L in 600km (not good at all). I asked him what happens afterwards and he said all he could do is put the old part back. WOW !!! so this thing will never resolve mind as well request for a new car cause clearly it is a defect. Anyone here actually had a breather hose replacement and it actually worked?
      • I still don't understand how this breather hose is supposed to help?
        Its clearly a piston ring sealing issue as per the LS1 engines. Oil gets past the rings gets burnt up and blown out the exhaust hence the oil spots on offending vehicles rear ends.
        2001 S4 Matte Charcoal metallic | M6 | MTM tuned | Zinram 3.5inch catback | SRM SMIC's | ST Coilovers | Work Meister S13p's
        2002 Bora 4Mo Indigo Blue Pearl | FK Coils | Air box swisscheesing | Audi B5 S4 Wheels
        • My experience (already related here):
          _Before breather pipe change: 1 liter every 10.000Km and big intake pipe completely oil-wet.
          _With new breather: in the last 2.000Km the oil get down on the dipstick of only about 1mm (halved) and the intake pipe is completely dry.
          • Originally posted by kawabanga View Post
            Same experience as kawabanga.....so far so good. I will post IF the situation goes to crap.
            Oh...just my 2 cents worth regarding oil brand. I still think that Liqui Moly Top Tec 4200 seems a better oil for the Polo engine. I was using this to top up and it seemed to stem the bleeding until the dealership changed the valve and hose. Funny, when they asked what I was using to top up, they didn't seem to know Liqui Moly???WTF? They suggested using Castrol Professional Titanium if top ups are required?
            2011 POLO GTI 3dr, Candy White, Audio-Comfort-Xenon Packs
            MODS: H&R Sport Springs - Bilstein B12s - Whiteline Sway Bar - Milltek Cat Back Exhaust - Sparco Assetto Gara Wheels
            • Originally posted by BLN355 View Post
              The problem is in the other direction - during the combustion stroke, pressure from the cylinder gets past the rings into the crankcase which causes excessive flow through the breather, carrying oil along with it into the inlet tract to get burnt up and blown out the exhaust hence the oil spots on offending vehicles rear ends.
              Originally posted by nomadx38 View Post
              As for the VW spec (VW 507), i think it mostly refers to an "emissions standard" like how many pollutants the oil gives off when burnt, how much drag it has on the crankshaft and thus fuel economy things like that.
              See http://www.vwwatercooled.com/forums/...nes-47140.html
              It's mostly to do with preventing intake buildup fuel not cleaning the inlet tract due to the direct injection
              Resident grumpy old fart
              • After thinking mine was a drinker being on the top up mark on the dipstick at 1700ks, just checked it then after a drive and now its at 3600k's and it hasn't moved at all. I have a Shell Helix sticker on my windscreen so assume thats what it was filled with originally. I topped it up with the proper Castrol at the 1700k mark with 1 litre and all seems fine.
                I did the warm it up to temp then give it some stick method to break it in and its running like a dream.
                • Done 12,000km now and total combined only have an oil lost of 2mm. Mine is 80% City driving 20% highway. 4 cross country trips.
                  I mean, we have heard countless oil issues but does it account for more than 10% of the cars ever produced by VAG group? There must be many owners without oil issues correct?
                  Only issue for mine is 4th gear while slowing down from 5000rpm, will encounter a loud "clank" crashing noise around 4000rpm. wonder if its a "end float" adjustment issue for its clutch issue?? Anyone?
                  • 2,700km in, and topped up 2.5L
                    This is horrible! I still have half of a 1L top up bottle I was given, once that is gone, its time to complain and get an oil consumption test done.
                    I am losing around 1L/1000km, anyone else getting these high numbers?
                    • Originally posted by Zakarados View Post
                      You won't get a consumption test until after you have done 5000km. VW will tell you that 1L/1000km when running in is normal.
                      • Originally posted by brad View Post
                        Wow, if that is the case, I should just ask for a 5L bottle to last me until 5000km.
                          yep
                          1234567890
                            Read through the thread mate, there are some with worse consumption than you.
                            This is more likely a mechatronics issue, the clutches are self adjusting and unless they were belted with a hammer during assembly (unlikely) then the mechatronics probably is preselecting gear 3 which is a notoriously rattly gear. have a check on the net about DSG rattles, most of them stem from a dodgy 3rd gear selector valve.
                            • Polo GTI High Oil Usage - Discussion Thread
                              Back on topic, I see where nomad is going because I too thought of tracking down the specific Castrol oil due to it being developed in conjunction with VAG etc. etc.
                              BUT.
                              The 2 times (factory and 15,000km service) that my car had the Castrol oil in it, it chewed through the oil around 1L/5000kms, maybe a little worse. However I have used Liqui Moly Top Tech 4200 on 2 fills now and have seen an oil consumption rate of around 1L/10,000kms.
                              I too agree that the car is noisier with the Castrol oil, not that I can remember what it sounds like anymore
                              • Originally posted by gavs View Post
                                Thanks Gavin, have not updated the DSG software to the latest version. The 1st gear simply shift up too soon and strains 2nd gear too much!
