I would go the Osrams or if you can find them, the IPF globes. Don't get anything higher than 4500K in colour because even at 4500K you have a severe drop off in penetration, the more yellow the light, the greater the penetration of light, hence why road markings above the snow line are yellow, the yellow penetrates through fog etc so you can see the lines.
Pics availably are all phone quality so not really usefull.. One of the members has the Phillips Diamond Vision and says they are even whiter than the Osrams and come pretty close to the LED's he has in his parking light
Don't know if you have the 1.2 TDI over there, but many over here have found out that ECU versions 88A and 88B are extremely sensitive for canbus light errors. Still not a big deal, easy to disable with vcds.
Don't know if VW has put these ECU's in more TDI's though
Ah yes, forgot about that.
Polos with a single headlight use a twin filament H4 60/55W bulb, those with dual headlights use a pair of H7 55W bulbs.
How do I know what globes I need? From memory I have a total of 10 globe's including indicator lights just at the front alone.
Indicator lights
Fog lights
Daylight lights (W5W)
Low beam lights ????
High beam lights ????
X2
The daylights also seem to be the low beam lights. I am very confused when it comes to lights on the car. You can't imagine how difficult it's been knowing what lights are on and off at all times of the day...???
One question, there is no auto setting on these Polo's is that correct? I was told from a friend (Golf owner) there is an auto setting and he just leaves it on that all the time. This isn't the case with us Polo owners???
GOLF GTI MY11 ADIDAS Candy White, Sunroof
GOLF GTI 40th ED, White with Sunroof
Side light illuminates with low beam, there is a VCDs code in order to have it auto as soon as the car is on. However I cannot find the code as of yet.
So really...i'm getting confused.
One Dealer says get philips Diamond Vision x 4 (two for low beam, two for high beam) with the LED parker I have found.
