New Polo problems - Register
  • Went to a couple mechanics and a Transmission dude today, They reckon the noise is definately coming from the gearbox!
    Taking it to VW tomorrow lets see what excuses they will come up with
    • Is yours a DSG box? Your experience doesn't inspire me with confidence in VG, keep us posted on what they find, perhaps it's just an isolated problem, something that inevitably occurs with production made cars
      2011 POLO GTI 3dr, Candy White, Audio-Comfort-Xenon Packs
      MODS: H&R Sport Springs - Bilstein B12s - Whiteline Sway Bar - Milltek Cat Back Exhaust - Sparco Assetto Gara Wheels
      • JimNiko - The DSG box does make a bit of a dull clunking/grinding noise at low revs/low speed... I noticed this too when I first picked my car up and took it back to have it checked. I was assured this was normal (the service guy couldn't even hear it for ages as I drove him around... Said he's gotten so accustomed to the noise it doesn't even register anymore)... 6 months and 7000kms later it's still running fine... Touch wood!
        Get it checked out anyway of course, but don't be surprised if they tell you it's normal...
        2010 VW Polo 77TSI Pearl Black, DSG, Sports Pack
        • Turned off my climate control today for the first time, and felt warm air on my face after a few minutes.
          The climate control had been at 22, but when it's turned off via the rotary dial, it appears to let hot air in to the cabin...
          Turning the unit on, and dial down to Lo, then off again the problem was solved....
          ...anyone else got climate control issues?
          MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
          • Originally posted by 77kw polo TSi View Post
            Nope. Have not noticed if any air comes in when it is off, but then its been on 18 since I got the car, even with the windows open <---helping the fight against global warming
            PS, how many times have you posted something then clicking on the big blue "+ Reply to thread" button and need to start all over again?
            POLO 77TSI DSG 5D - MY11 - REFLEX SILVER - COMFORT PACK
            Engine - K&N Air Filter (e-2997)
            AV - Rockford Fosgate T1652-S , T1652 and P3L-S12 Sub. Alpine MRP-F600 and Alpine MRP-M500, Dynamat
            Planned - lots, but the "financial manager" says NO
            • I have just purchased a new polo 77tsi manual, and one day after delivery had to take it back as I had a miss at about 1000 rev every time I revved the motor or started in first gear.Each time the motor would give a distinct shake when the blip or inbalance would occur, and then once driven through it all was fine.Solitaires here in Adelaide reprogrammed the software, but that has made no difference. I also have a strange rattle which sounds like it comes with vibration from the engine only in neutral and on idle. At times it sounds like the polo is a diesel, but it fades in and out. At times it sounds like it comes from the engine, and other times from in the dash. Any clues anyone? Waza
              • Originally posted by waza View Post
                Hi Waza.
                Ours had a rattle (front RHS) when the air cond was off and in idle.
                The fuel line was vibrating against the body where it disappears down into the chassis and it appears to be typical of this model (77TSI) of POLO.
                I have fixed it by sliding some 1/2" rubber A/C pipe insulation hose (avail from Bunnings) over the fuel line. It was slipped over the fuel line by slitting the A/C hose down the length, and then feeding it down over the fuel line until it reached the bottom - probably about 300mm - The rattle is now gone.
                I really did expect a better design from VW on something so simple !
                • Well, it looks like it didn't take long for the DSG issues to start in this car either... I wonder how long it will be before the 1.4TSI's start blowing up like in the Mk6 Golfs....
                  • Hey guys,
                    Picked up a Manual TSI about 2-3 weeks ago (2011 built and complied), cars been going good until the last week or so. Noticed that on a cold start the engine surges between about 900 - 1300 rpm for about 2 mins... then drops down to the normal idle rpm. Its seems half the time it does this, the other half is normal where it will sit at 1100rpm for about 2 mins and then drop to 750.
                    The only other problems i have is that the rain sensing wipers don't work, they still act like the standard intermittent. And every now and then the Hill Assist (think that's what they call it) doesn't turn on. The cars going back to get this fixed so i think i might mention the irregular revving on start-up.
                    2011 VW Polo 77TSI | Manual | Savannah Yellow | Comfort Pack | Sports Pack |
                    Installed: Whiteline Rear Sway Bar, H&R Springs, Resonator Delete
                    • WOW, more problems. I hope VG start ironing all these issues out very soon. Hey Trepid4tion, I think the rain sensing wipers only automatically adjust with speed when it's raining eg. move faster as you increase speed and vica versa, at least that is the way it worked on my Citroen C4. I know it sounds a little misleading and one thinks that they should turn on automatically when it starts raining, but I don't believe it is the way they work, I could be wrong, but that is my experience.
                      • Originally posted by GTI JOE View Post
                        your experience with Citreon is valid, but not relevant here.
                        The rain sensing wipers on a VW vehicle are activated via sensors attached to the windscreen (behind the rear vision mirror mount). The speed of the wipers does not vary, however, the intermittent delay will vary, depending on how much water is remaining @ the sensors after each wipe of the blades. So you may have a vary long delay between wipes, or the sensor may decrease wiper delay, to the extent that the wipers go to continuous wipe. IMHO should the downpour be of such intensity, the wipers will go to speed 2 (as if you had selected the faster wipe speed), but I am yet to experience that in 3 years of ownership with our MKV R32
                        MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
                        2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
                        • Originally posted by FJ Steve View Post
                          Delay and speed do vary depending upon intensity, and YES you can leave it on setting one, without any rain and rest assured they will start when rain appears. As tested from Melbourne to Canberra
                          • Originally posted by Casper View Post
                            So your sayi8ng it could be normal?
                            This seems a lot louder than what i have expriecned in the past with other DSG's
                            • Originally posted by JimNiko View Post
                              No clunking noise in mine.
                              • Originally posted by broxigar1983 View Post
                                Mine is whisper quiet.
