Polo 6R 1.2 Oil leak
  • Polo 6R 1.2 Oil leak
    Hi all I have a weird oil leak between the pipe from the airbox and the turbo! has anyone seen this and does anyone know what I need to fix it?
    Could it be the same issue this guy had?
    Oil Seep / Leak from PCV Valves and Wastegate Rattle - 6R TSI
    B9 Audi SQ5
      Thanks for the reply Lucas, I did see this and checked all those connections, no oil present in those areas.
        My wife's 6R 1.2 had a similar problem. Turned out to be the oil separator that was leaking. This was replaced by VW under warranty.
        It was picked up by an independent mechanic initially.
