I am currently using 95 ULP fuel as recommended. Can i use 91 ULP ? This is cheaper obviously, most of my driving is around town, with the odd 1000 km trip. Geriatric driver
2015-17 Polo 81TSi fuel.
No stick with the 95RON fuel you will end up damaging your motor with low quality fuel it says min 95ron on the cap for a good reason2017 Golf Alltrack 135tdi All options
It's a no from me.Originally posted by leeming View PostI am currently using 95 ULP fuel as recommended. Can i use 91 ULP ? This is cheaper obviously, most of my driving is around town, with the odd 1000 km trip. Geriatric driver
The knock sensors will sense the detonation and retard the timing, richen the mixture & reduce boost, so you'll get worse fuel economy and the cost per kilometre will be higher.
If you want to save a few cents, you might get away with a tank of e10 94RON but again, on a cents per km basis you won't save much.
Personally, in hot climates like yours, I'd run 98ron.
Your best way to save on fuel costs is to drive economically and make sure your tyres are inflated properly - 36-40psi.carandimage The place where Off-Topic is On-Topic
