Map updates
  • Originally posted by oj4rec View Post
    DiscoverCare only shows 0076 to me. Am I missing something?
    discovercare hasn’t ticked over yet. My gut feel is that it’s a date formatting issue - wait until 6th or 7th of July and try again.
    • Just go here Pick your model Pick your MIB and download the required map Unzip it to a folder Put contents of folder in the ROOT directory of an SD card and away you go
      Volkswagen Map & Softwareupdates
      All files are dated this month
      Should end up with this on SD card
      MIB 1
      MIB 2
      metainfo 2
      WMP info
      Thats whats on my card
      • Okay I just tried this and heres what I got. Using discover care 1.04 I ended up with ROW 76
        BY doing what i said above and NOT USING Discover care i got ROW79 on 3 different attempts
        So just download it and do as I said and you end up at the same point by a different route
        • Downloaded and upgraded, took over an hour in the car.
          Passat Alltrack Wolfsburg 2017
          • I have followed the instruction to download and extract P79_N60S5MIBH3_ROW.7z.
            Inserting the card into a slot gives me a message that software update is available.
            Though update process searches for a while and ends up with "Error: no data available. Please insert a source with software update data or check the source."
            SanDisk Ultra MicroSD 32GB (tried with an SD adapter and Kingston USB reader).
            206TSI MY16 Discovery Pro 2
            Software:0814
            Navigation database: V03959801BH0071 ROW 2018/2019
            Nick
            Passat 206TSI R-Line (MY17)
            • Needs to go into SD slot in glove box, I think.
              • Yes, I've tried both SD slots as well as USB slot between the seats.
                Nick
                • Is it the correct version for your car.
                  One is 4GB the other 22GB, my Passat Alltrack 2017 need the 2015 22GB version
                  • It's the big one (24GB).
                    Nick
                      Software:0814
                      Heres what the contents of the card should look like When it finds it just touch update
                      Did you select the correct MIB mine is the right hand plain glass one Whats yours
                      • Well, that's the thing ... it doesn't find it.
                        Mine is Pro Gen 2 (2016)
                        Nick
                          Did you select correct year for your Tig
                          Is the same map as I just tried it so you are doing something wrong
                          Download
                          Extract to a folder
                          Copy CONTENTS of the folder to root directory of SD card and the root directory will look like my pic.
                          If you copy the WHOLE FOLDER over it wont find it Been there found that out
                          • It's Passat not Tig ... but yes the archive looks to be correct. Extracted and copied as required.
                            As I said, when inserting the media into unit it says update is available, while update button in setup can't find it.
                            Nick
                              Read what i posted carefully as if you copy the WHOLE FOLDER you extracted to to the Sd card it WONT WORK
                              You only copy the CONTENTS of it The screenshot is of the contents of the extracted folder on the SD card and is the ROOT DIRECTORY of the card
                              • yes, the content is in the root.
                                Nick
