Audio Upgrade Options - Help!!!
    Hey
    How did you go with your searching? Im actually installing a 12" sub in my 206 ATM and was trolling for some wiring diagrams.
    Iv put my sub in the spare wheel so it doesnt take up anyroom in my boot area.
    does anyone know if there is a stock amp in the b8's I had a b7 all track which didnt. But i was told that this car had the upgraded stereo already.
    Cheers Ben
      Originally posted by Diegothecat View Post
      Hey
      Cheers Ben
      I got my MRXV75 Alpine Amp, Audison Bit 10 and 12inch sub installed the other week. It's made a huge improvement. Speakers are still stock and are reasonably capable, it's the factory AMP that is the weak point. I already had the gear. The install cost me about 500ish with a wiring kit. The AMP and Bit 10 fit perfectly under the passenger seat. I can snap some pics later if you want to see what it looks like.
      MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
      MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
        I dId mine the other day and am very happy with the setup. I had the same in my alltrack but the sub was is a small box. This is way better.
          I like the look of that spare mounted sub..... Do you have a link?
            rave
            I am in Sydney, do you know any good car audio installer in here? What sub did you use as well?
            Current: MY16 132TSI | Luxury | R-Line
            MY14 C250 W205 | Command | Vision | Exclusive | Seat Comfort
            MY13 A200 W176 | Command | Vision | Exclusive | Seat Comfort
              Go for JL Audio speakers they are well worth the Money i had them in my ford laser the TR range. Now that my car is written off i'm am going to buy a passat but still in negotian stage with the dealer.
                Thats.an.Alpine.Type.S.sub!
                  There's always the Dynaudio Esotec range (more affordable than Esotar).
                  An Esotec system is still more expensive than the (non-existent) Dynaudio factory option, but better quality. Expect to spend a few $K for front and rear component speakers + amp.
                    I'm using an Alpine MRX Amp (5ch) with an Audison Bit 10 DRC. The amp is powering the factory speaker setup and a 12" Rockford P2 Sub. The factory speakers aren't too bad when they are Amped up and tuned for use with a sub. They'll certainly be upgraded at some point but they do the job for now, a major improvement over factory overall.
                      Could you provide more details on how it was fitted?
                      ie. Is there a digital output from the existing head unit.
                      Where did you place the digital processor and amp?
                      How was the speaker wiring routed?
                      Where did you access the high current power input for the amp?
                      Thanks
                        I think you can code your RNS 510 to deliver low-level (RCA-level) outputs to an amp through the speaker outputs..
                        From memory, that was the case for my 2008 R36, where Dynaudio was an option (luckily mine came with all the right wiring and plugs for a plug-n-play retrofit)...
                        Being Brisbane-based, I'd recommend talking to JKU.com.au (at Maroochydore).
                        • #27
                          Yep coding is well documented.
                          5min job.
                          Sent from my HTC 10 using Tapatalk
                          • #28
                            Any reputable installer in Sydney? Marty@FHRX is fully booked. Lifestyle store at Parramatta quoted me $800 to install and amp, subwoofer and front speakers (installation only without components). Not sure if it is a good price?
                            • #29
                              Thanks
                              I had someone do this install job, but know how they did it.
                              - Power is from the battery (4 gauge power wire)
                              - Plenty of earth points under the carpet
                              - Amp is under the front passenger seat (fits perfectly)
                              - Bit Ten is under the front passenger seat, just behind the amp
                              - The Controller for the bit 10 is routed all the way to the compartment just beneath the headlight switch. It's rather neat.
                              - Speakers are wired to the thingo in the glove box, I had them use adapters on everything, that way it's easy to uninstall if I want to.
                              • #30
                                My install job was $600 with me providing the gear except for the wiring kit.
