Vibration noise coming from door trims, anyone?
  • Vibration noise coming from door trims, anyone?
    Hi
    My Passat got some vibration noises coming from the door trims when the bass was booming or harsh roads.
    I don't know if it is the speaker hitting something, bottom out or loose door trims and panels. Sometimes, it sounds like the windows were vibrating and hitting too.
    The car is heading to its first service two weeks later.
    Anyone has the same issue or experience?
    B pillar trims? Door Panel? Door trims? Windows? Speakers?
    Neal
    Mine has a small rattle on the door trim, at the base of the drivers window. This only occurs on really rough roads, and is only just audible. In every other scenario, its tight as a drum. 10,000kms travelled.
    Mine - Mustang GT MY20 - Carbonised Grey - "Nicky"
    Hers - T-Roc 140 TSI Sport MY21 - Reveena Blue - "Rocky"
    Previous - Passat 206TSI MY17 - Night Blue
      Very very minor noise in my rear passenger speaker/door trim. A firm push on the speak and it was gone (for now).
      Otherwise, tighter than a nun!
        I have a slight rattle coming from the the silver strip on the drivers door (the same the led light strip is on).
        It's intermittent but bass from the speakers sets it right off, and if I hold my elbow against it while driving it stops.
        VW had a look and said they tightened everything but the issue still persists. Bloody annoying!
        MY17 206 R-Line Passat Sedan in Black
        MY16 Golf 110 R-Line In White
          In the B7's the dash binnacle trim would rattle I fixed mine by putting foam in behind it and thin foam over the clips and pushing them in firmly. Took ages to work out what it was but doesnt do it any more
            Sounds exactly what I had on my rear passenger speaker. Such is life with snap-lock cars. I just pushed on mine and it stopped, at least for now.
            As an aside, I installed my new 2 channel dashcam yesterday. Having installed many over the years, I have to say the VW trim is absolutely the tightest and stiffest I've done after removing tailgate, roof, and sill trims. Many Commodores and Asian cars have had very flexible trim and pull apart easily. The VW was a bitch! But put back together and it's all still tight as a mofo. Took it for a drive and no noise.
              Constant buzz from right rear door trim around the small speaker area in my Wolfsburg Alltrack. Pressing the silver trim will temporarily suppress it, but it always returns. Right near my ear and very annoying. It was also identified by the dealer and they’re seeking to replace the trim. Worse when it’s cold and on coarse chip roads.
                what you describe is what I can hear in my Alltrack Wolfsburg. Hmmm... that being said, I don’t like having dealers pull my car apart so am not inclined to have the dealer do anything with it.
                  Yep, agreed but it is driving me insane. I’ve opted for the trim replacement just to get it fixed. Fingers crossed.
                    Are you replacing the trim only or the whole door panel?
                      Try what I did it worked a treat If you use body tools the panels come off ok except for the front door panels which have a clip right in the very centre. A long heavy screwdriver and a little twist in against it got it out I spread the metal clips a bit when replacing the panels and I think they gripped a bit better Has been 3 years and its still quiet
                      Edit Spelling
                        Originally posted by Hillbilly View Post
                        Try what I did it worked a treat If you use body tools the panels come off ok except for the front door panels which have a clip right in the very centre. A long heavy screwdriver and a little twist in against it got it out I spread the meat clips abit when replacing the panels and I think they gripped a bit better Has been 3 years and its still quiet
                        I’m planning to do that if no one can treat it.
                        Great advice.
                        Thank you
                          Great advice.
                          Thank you
                          Was only thin foam like 5-8mm thick and quite pliable. not styrene stuff more like wrapping stuff
                            Sound good.
                              Yet to see. Early suggestions is they’re getting the speaker part from Germany, but have yet to clarify.
