Hey all. Has anyone experienced a problem with their head unit and the reverse camera unit that after you reverse and then put in drive or park the head unit goes black but stays with the reverse grid lines?
Bending guidelines is a highline camera module (not the named of the car model).
You need to get a scan of the car for faults codes. That will give some more info about what is failing.
Sent from my HTC 10 using Tapatalk
2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC| 2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|3D colour cluster|Quad LED tail rings|Climatronics upgrade|Dynaudio retrofit|B7 RLine Flat Steering Wheel|3AA CCM|TPMS Direct|B7 Adaptive Cruise with Front Assist|Discover Media retrofit|PLA 2.0|Lane Assist|BCM retrofit|High Beam Assist|DQ500
Fingers crossed that the issue doesn't return. It's not at all unusual with IT equipment to get the occasional intermittent fault which does not recur.
Can someone advise how to update the maps in my head unit?
You can buy a V9 for a ridiculous price or just put up with what you have as there are apparently no more updates for a 510.
Cheaper to spend $150 for a good Tomtom than buy a new VW map. or for a lot more buy the new model VW GPS unit
