Got this fault code:
01334 - Door Control Module, Rear Right (J389)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 4
Fault frequency: 1
Reset counter: 212
Milege: 78374 km
Time indication: 0
Date: 2015. 10. 08
Time: 11:26:51
First of all, I tried to clear the code but it just won't go away.
On the other hand, funny enough, I just can't figure out what problem it may actually cause! The door locks and unlocks alright. The computer senses the door open (courtesy light on, door open indicated on dashboard) and close. I even tried unlock the car with the remote and then open and shut the rear right door. It remains unlock after 30 seconds so the computer know that door has been opened. It is also locked automatically after driving off over 10km/h. The electric window also works beautifully.
Any idea what's going on or how to clear the fault code?
Edit: The part, 1K0 959 704 AB, as indicated in VCDS, looks like the window motor. But the electric window definitely works from the control that door and also from the driver's.
014 - Defective
Freeze Frame:
Fault Priority: 4
Fault frequency: 1
Reset counter: 212
Milege: 78374 km
Time indication: 0
Date: 2015. 10. 08
Time: 11:26:51
