My windscreen washer system is losing fluid with a few drips sometimes visible under the car. The leak is very slow so I'm hoping it's something simple like a loose hose rather than a split bottle which I understand is located in the front bumper. Has anyone had this problem? Would appreciate advice on the best place to start looking. Thanks.
Windscreen washer system losing fluid - help please
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s -
I had a similar issue. My leak was a fast one though and the spray nozzles were not spraying as effectively. It was the discharge hose from the pump. It's a little black corrugated hose. I glued it back together and haven't had any issues since. It was a bit of a bugger to get at though. The front right half of the bumper needs to come off.
Thanks Domatron. I'll check that black corrugated hose first. I've been researching this a bit more and it seems a number of owners have had trouble with the rubber gasket/seal around the pump.
VWVortex.com - Any one else have a leaking windsheild washer reservoir ?
Before I take the front off the car, I'm going to see what I can access from underneath and from the right front wheel well with the inner plastic liner removed.2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Originally posted by Umai Naa!! View PostYou might be able to get to the pump with removal of the undertray and lower inner guard liner.
They're a cow of a thing to remove the whole washer bottle. Heaps of hidden bolts and nuts.2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
