B7 Passat Audio static issue
  • B7 Passat Audio static issue
    I tried a search, but was unable to find exactly what I have been experiencing. I have owned my 2015 Passat TDi for a month or so now, and absolutely love everything about it! However, there is one small annoyance that has become increasingly apparent lately, to do with the audio system. I have a 32GB USB stick plugged into the cable in the center console compartment that I play my music off. It has been playing funny buggers, where by when the car is turned on, it will (for lack of a better description) hiss at me! Almost like a static or distortion sound, which will not go away unless I switch to radio or turn the car off. Has anyone else experienced this? I will bring it up at my first service, but thought I would ask here also!
    B7 Passat 130TDi Highline Special Model Candy White DSG
    Mine hasnt got that I use an SD card or the HDD in the RNS510 and dont have any problems Only have a mini aux jack in my centre console but have the MIDI in the glovebox which I never use any more.
      Thanks for the response! I might have to look into copying my music to the built in HDD then.
        Is a very slow process to do that An SD card is better and you can add to it as you like and just stick it back in.
          Not uncommon with the USB sticks.
          Have seen this in the past.
          SD card is the preferred method, but just be certain you're using the correct card.
            Thanks heaps for the advice! Would you please also be able to advise what is the correct SD card I should be looking for?
