G-8VXWWTRHPN RNS-510 changed colors overnight - VWWatercooled Australia
  • RNS-510 changed colors overnight
    The color scheme of the RNS-510 in my passat changed overnight from the usual premium colorskin to the plain one with white buttons. Additionally, I think the compass is no longer available in the MFD. Am concerned this might be due to a faulty comfort module or similar? Has anyone else had similar problems in the past?
    132TSI Tiguan Allspace
    You'll need to get a fault scan done with VCDS or similar to find what the issue is.
    If I were to guess I would say the coding on the RNS has been reset to defaults.
      I've got these errors logged;
      Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
      Part No SW: 1T0 035 680 D HW: 1T0 035 680 D
      Component: RNS-MID H70 4120
      Revision: AB001001 Serial number: VWZ6Z7M6168141
      Coding: 00000400000000000011
      Shop #: WSC 05314 000 00000
      VCID: 2F43CEF17EA53346D7-807B
      Subsystem 1 - Part No: 7L6 919 859 G
      Component: AUNZ V6 7920
      1 Fault Found:
      00862 - Antenna for GPS Navigation (R50/R52)
      007 - Short to Ground - Intermittent
      Freeze Frame:
      Fault Status: 00100111
      Fault Priority: 5
      Fault Frequency: 1
      Reset counter: 240
      Mileage: 98714 km
      Time Indication: 0
      Date: 2016.06.14
      Time: 17:22:19
      Address 56: Radio (J0506) Labels: 1T0-035-680.clb
      1 Fault Found:
      Freeze Frame:
      Fault Priority: 5
      Fault Frequency: 1
      Reset counter: 240
      Mileage: 98714 km
      Time Indication: 0
      Date: 2016.06.14
      Time: 17:22:19
        That's not an uncommon fault and nothing to worry about unless you aren't getting a GPS signal.
        Coding doesn't look complete but I don't have a unit in front of me right now to check what those coding bits mean.
        Also check your canbus gateway installation list to ensure addresses 37/56 are enabled.
          Ok, am not sure how to chek if the addresses are enabled. I tried changing the display to premium, and am getting a message about an un-initialized control module. Safe to proceed?
Name:	Screen Shot 2016-06-28 at 3.11.12 PM.jpg
            Yes just follow the suggestion and use the recommended values for WSC/Equipment. Some control modules do not like having all zeroes for these values.
              Ok, I managed to get the colors adjusted by coding it. But today after three days it's back to the original color scheme again. Am wondering if this coding is stored in the unit iself or in a different module? The RNS-510 has been very slow to start up in the last year, so I've been suspecting the hard drive might have some bad sectors or similar.
              But I am also seing that an automatic scan fails to reach a few other modules as well, am unsure if this is a more serious problem or can be ignored?
              Address 16: Steering wheel
              Cannot be reached
              Address 4C: Tire Pressure II
              Cannot be reached
              Address 52: Door Elect, Pass.
              Cannot be reached
              Address 77: Telephone
              Cannot be reached
                The RNS itself stores the coding. In flash memory, not on the hard drive.
                If you are having problems with other modules as well the most obvious candidate would be the canbus gateway. Fairly quick and easy to swap it out with a new one.
                  Been to busy for any updates until now. I've tried changing the coding back in the headunit to use the premium colors, and enable BAP which then gives me the correct display, and lets the MFD present the navigation and audio information again. But it keeps resetting overnight. I assume this is due to faults in the RNS-510s flash memory. Is there any way to fix this other than replacing the unit?
                  Edit: just adding that the headunit is very slow to start from cold. I'm already down the driveway long before the rear view camera is up and running.
                    When I had SatNav problems like this on my Golf Mk V, after being sent to the dealer twice for diagnosis (and being told its "out of warranty"), it was the battery...
                      The main battery? I've got it tested when I do my tyres, and they say it's in good condition. I'd expect flash memory to survive a powerloss in any case.
                        I'm looking to upgrade my basic radio to one with bluetooth, GPS etc...I have a 2008 R36 sedan, do I use RNS510 or ??
                          You can use an RNS510 which is the OEM option.
                          Has the best integration.
                          For Bluetooth that then requires a 9ZA module, and given you have a red MFD you would also need a FISlink. This converts the BT's 'BAP' output to 'DDP' for your instrument cluster.
                          Another option is the RCD330G plus which does not have navigation, but has integrated bluetooth (no seperate module needed) and Apple Carplay which can use your apple phone for navigation. It doesn't support Android Auto at this point but that support may be coming.
                            Thanks , will look into that....
                              Hey, I just clicked on Kamold's fislink web link and the page says:
                              "Another extra function is that solve battery drain issues with newest RNS-510 Firmwares (from 26xx) in cars equipped with gateways prior to index K (not necessary to change gateway to avoid battery drain)"
                              Could this be your problem?
